Question about Norcent Technologies LM-762 17" Monitor
Norcent Monitor LM-762 right-half of screen is white columns
Running Norcent Monitor with my Dell Inspiron 5100 laptop; worked fine for several months. Without warning, it split the Norcent Monitor screen image in half, vertically--the left side is in full color, and displays half of the total image. The right side is all white with 4 or 5 columns delineated by narrow black vertical lines -- almost like columns in an Excel spreadsheet, but all evenly spaced and of course no horizontal lines.
About the same time I had occasional problems with Excel...sometimes a spreadsheet would "lose" the Excel menus at the top of the screen and in their place it would have the "e" for internet explorer... as if the Excel spreadsheet had morphed into an internet page.
How can I find a driver for Norcent? (to re-load) I've tried several websites but nothing delivers a solution. At driver detective it reported {Dell's ??] Mobility Radeon 7500C was out of date...I see this name when I select the use of two monitors. Is this the problem? Or should I remove Excel and re-load Excel? I don't need the monitor often, but when I do, gosh, I really need it. Thanks.
4 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Norcent--screen flashing repeaditly
Could be a short in the monitor video cable.
Posted on Jun 30, 2007
budmrtn
  • 11361 Answers
SOURCE: Where can I buy a replacement inverter for Norcent
You can try here: http://www.lcdparts.net/DI3D.aspx
You need to get the numbers as printed on the PCBA to see if they have it in stock.
Posted on Feb 22, 2010
  • 1684 Answers
SOURCE: I need the ac adapter
That model uses a 12v 4 to 5 amp power adapter. Here is a link here you can get one.
http://www.ccl-la.com/catalog/product_info.php?products_id=48
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Oct 06, 2011
My dell inspiron m5030 has a white screen any ideas what it is?
LCD video cable. Plus, to connect and activate an external monitor, you click Fn + F2, not F8.
May 20, 2012 | Dell Inspiron M5030 Laptop
Hello my Dell inspiron has a white screen upon start up but once it's on the login screen it's fine after that is it the cable coming loose or a bad video chip plz help?
Try connecting an externalmonitor to the Dell Inspiron and see if the white screen is also presenton the monitor. If the monitor display is fine, then your laptop's LCD displaypanel is defective. If the monitor also displays the white screen, then yourproblem is with either the video card or motherboard located inside yourlaptop. Also try booting the computer in safe mode by tapping the key when you turn it on. If it works that way you might have a video software driver issue.
Aug 17, 2011 | Dell Inspiron N5030 Notebook PC
So I'm turning on my inspiron 5100 and all i get is a white screen. It sounds like it's on but the screen remains blank white?
Hi Donny,
A white screen usually means the LCD panel has failed/worn out. Here's an easy way to make sure. Get your laptop to an external monitor, whether at your home or a friend's place, and with the laptop off and the external monitor off, connect the monitor video (vga) cable to your laptop. Turn them both on and then on your Dell laptop hold down the fn key down in the bottom left hand corner of the keyboard and press the F8 key up at the top. That transfers the video signal to the external monitor.
If the external monitor shows your laptops normal desktop and icons, then you know for sure the LCD screen on your laptop is worn out. If you get the same white screen on the external monitor, it means the video card/controller on the motherboard of your laptop has worn out and you can move ahead with deciding on repairs or other options.
Good Luck.
PS....if the F8 key doesn't transfer the video signal. look at all the F keys for one that says CRT or one that has a little picture of a monitor to transfer the signal.
Sep 01, 2010 | Dell Inspiron 5100 Notebook
I have a insprion 1545 that half of the screen is white with vertical lines on a white back ground. The other half is fine but can only view the left half of the screen. I hooked it to an external monitor...
It is a screen problem. You have to replace the LCD. It is either cracked or the electronics of the LCD is faulty. Find the part number on the back of the LCD and look for it on ebay.
Aug 08, 2010 | Dell Inspiron 1545 Notebook
Hi, I have a dell inspiron 5100. I have two problems. 1) My screen is completely black and I have to use an external monitor. When I start my laptop, I can see the Dell Logo and after that is when...
for your video problem, you may be stuck in a different mode try holding the Fn key and hit F8 this toggles through the modes
1 - LCD on laptop only
2 - LCD and external Monitor
3 - External monitor Only
if this does not work you may have a LCD issue with the laptop .. let me know how it goes first
Feb 02, 2010 | Dell Inspiron 5100 Laptop
No sound coming from monitor
Make sure your stereo cable is connected properly and in system speaker icon is showing and it is not mute.
Dec 31, 2009 | Norcent Technologies LM-762 17" Monitor
I cant get the right resolution on my Norcent monitor
If the company said you need a driver, how come the monitor don't come with a CD to install the Driver? How come they did not point out how you can get the Driver? Look in Device Manager under "Monitors". Does it say "Plug and Play"? If so, you don't need any monitor driver. Try adjusting the resolution on the desktop also, right click in desktop, properties, settings, adjust the slider...
Aug 12, 2009 | Norcent Technologies LM-962 19" LCD...
Monitor
probably you have tried opening your laptop and messed up with the cables... or your unit receive a hard bump at the top right corner if i'm not mistaken....
LCD and keyboard laptop cable usually are loosen with this kind of problems... check the cables and you can rank me if this helps... ^_^
Jan 20, 2008 | Dell Inspiron E1505 Notebook
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
Norcent Technologies LM-762 17" Monitor Logo
150 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
