Question about Sanyo Xacti VPC-T700 Digital Camera
I have lost my charger and was wandering if I could charge the camera by connecting to the usb port on my computer. I have it connected to the computer now and I would like to know if it can charge the battery.
  • 68 Answers
If your pc suit for the camera is already installed,it can charge the cam..:))
Posted on Mar 10, 2009
2 Suggested Answers
  • 378 Answers
SOURCE: Charge from USB
yes
Posted on Aug 13, 2009
I lost my fujifilm finepix jx 400 battary charger and i want to use my usb cable to charge it is it possible i plug it but it seems doesn't charge
The JX-400 is a camera, not a battery charger. Connecting it to a computer's USB port simply drains the battery faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
One source for a battery charger is http://www.overstock.com/Electronics/BasAcc-Battery-Charger-Set-for-NP-45-Fuji-FinePix-S610-J110-J150W/7124327/product.html?searchidx=3
Feb 15, 2014 | Cameras
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
Dec 13, 2012 | Vivitar ViviCam 8025 Digital Camera
I Have Misplaced My Charger And I Am Wondering If There Is Any Other Way To Charge It Like Maybe In The Computer?
Yes, you can charge the battery by connecting the camera to a powered USB port. Be aware that not all computer USB ports put out enough current to charge batteries, and you want to connect it directly, not through a hub. Alternatively you can use a USB charger that plugs into a wall outlet; such devices are available for cell phones.
Jul 30, 2011 | Vivitar ViviCam 8025 Digital Camera
Is it possible to obtain a charger for a Vivitar vivicam 8025
One way to charge the battery is via the USB connection. Connect the camera to a powered USB port (not all computer USB ports put out enough current for the job, however). Another is to use a USB charger, as available for many cell phones. You should be able to find such a charger at just about any department, electronics, or office-supply store.
May 16, 2011 | Cameras
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 | Cameras
Failing to charge battery. Which is the charging port on the camera, is it the round port or rectangular port. I have a USB charger but not sure of right cable for charging. CameraKCCKP94536137
retangular should be your charging usb connect port,,usally always is,,the other is probly your usb slot to connect to a computer,,good luck,,
Nov 20, 2010 | Cameras
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 30, 2010 | Jazz HDV-188 Camcorder
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
Oct 29, 2010 | Cameras
My camera needs to be charged and i have lost the battery charger. so i put my camera on the usb cord and into the computer and tried to turn it on but it wont work.
You don't say what model camera it is, so I am going to have to do some guessing. If your battery charger normally charges the battery in the camera, then it probably will charge when connected to the computer by the USB lead. However, some cameras require the battery to be taken out and charged in an external charger. If that is the case with yours, then it probably won't charge by connecting to the computer.
It is normal for a camera connected to a computer via the USB lead to go into a kind of passive mode, just acting as an external disk drive so that files can be transferred, so not being able to turn the camera on while it is so connected might be normal. However, if you mean that you left it connected for awhile to charge up, but it wouldn't turn on after you disconnected it, then it is obvious that it cannot be charged up that way.
Oct 20, 2010 | Sanyo Cameras
WILL CAMERA CHARGE CONNECTED THROUGH USB INTO THE COMPUTER OR IS THE DOCK FOR THE CHARGER THE ONLY WAY
The S51c will NOT charge through the USB port. The camera does not include any charging circuitry, which is why it comes with a separate battery charger. Connecting the USB port only drains the battery faster, as the camera now has to communicate with the computer (even if only to say it has nothing to say).
The included charger isn't the only way... you can get third-party chargers that will let you charge, for example, from a car cigarette lighter. But you do need to use a charger, not the USB port.
Apr 19, 2010 | Nikon Coolpix S51c Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
132 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
