Question about HP Office Equipment & Supplies
My HP officejet J5783 says on the display "turn power off and on" with the quality lights, the power button and the exclamation mark next to the setup flashing. No matter how many times I've switched it off and on, this remains. It happens whether printer is connected to the computer or not. Unable to print/scan/fax currently. Could you please assist?
5 Suggested Answers
  • 24 Answers
SOURCE: Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Posted on Sep 24, 2007
SOURCE: HP PSC 1315 Scanning problems
If you're using windows try using window's built in scanning camera wizard (this worked perfectly for my psc 1315). Go to Start -> settings -> control panel -> Scanners and Cameras
Posted on Nov 30, 2007
professor_sc
  • 180 Answers
SOURCE: HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Posted on Nov 29, 2008
SOURCE: hp officejet 5600 wont turn on
I cannot solve that, but when my printer does that, i turn off the computor and printer then redo the cording, unplug and plug it back and usualy it is enough. Sometime the cartridge in not well inserted, or there is a paper jam.
I have a similar problem except that now my printer do not even have the question mark. It is like it is totaly out of power
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Posted on Feb 04, 2009
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
I have an officejet 5610 all-in-one inkjet printer. There is an ornage exclamation mark next to the setup between the pound sign and the setup button that keeps blinking. How do I get it to quit. I...
The Exclamation mark is an Attention: error indicator. There is a problem that you need to fix. You need to fix the problem. Was there is any message on the LCD screen when you started having the error?
Press Cancel and try printing again since you apparently cleared the LCD message. The problem could be a paper jam, no paper in the paper tray (or the printer can't pick up the paper), an ink issue or something else.
Please add a comment with the error message for additional support. I need more information to tell you what steps are most likely to solve your problem.
Apr 19, 2012 | HP Officejet 5610v All-In-One InkJet...
Blinking orange exclamation light next to the on button... ldc screen reads cartridge error see product documentation
Have you downloaded any HP software lately, I did that and made my printer in to a doorstop! HP said tough????
Mar 09, 2011 | HP Officejet 4215v All-in-One Printer
I "m getting error 252*
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
The USB printer cable looks like the image below.
3. Open the Cartridge Door and remove the cartridge. Refer to the image below.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Mar 06, 2011 | HP Photosmart Premium C309A All-In-One...
Lights flashing, but there is no one home
no.the problem is carrage unit .change the carrage unit
Sep 24, 2009 | HP Officejet 4355 All-In-One InkJet...
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet 5600 wont turn on
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 7410 - No display and orange exclamation point is lit
Unplug your power supply and leave it off for like ten minutes, then replug it and see if it will initiate itself, if not it sounds like serious malfunction.
Aug 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Power on,amber loight led on and no action
Exclamation light
The amber light in the shape of an exclamation mark (!) blinks when the unit requires attention. The display will give further information. The light is off when no attention is required.
Sep 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
279 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
