Question about Thorens Audio Players & Recorders
Turntable belt drive keeps slipping off.
I have a Thorens TD 280 turntable that I bought new 20 odd years ago. Every time I press the start button the belt slips off the drive wheels and I have to take the record, rubber and plate off to manually replace the rubber belt. The only way to prevent this is by slowly and carefully spinning the record with my finger until it reaches something like the sorrect speed and only then pressing the button to start the motor. What's going on here? Is the belt worn/stretched and needing replacement? Where do I get a replacement belt? Thanks in advance for any help, Gary.
    Problem Solver:
  • 18 Answers
I have a Linn LP12. At least in the case of my turntable, that's just how you are supposed to use it (i.e. this is what the manual says). You could get a replacement belt f you like, but I would guess it will not make a difference - that is, I think you do not need a replacement belt.
However, in my case I don't have to be very careful about the start-up push on the turntable, just one tweak to get it rotating at about the right speed is enough in my case.
Posted on Apr 13, 2009
Turntable must be started by hand
This sounds like the stepper motor that drives the turntable is failing. Are there any good DJ shops near to you?
May 20, 2008 | Thorens TD-170 Turntable
Thorens TD190 speed problem
Depends if it is a belt drive or direct drive turntable. Most problems like this on a belt are caused by the belt itself, which will be found by lifting the platter matt up. If you need to replace the belt make a note of how it fits before removing it. You can find the belt by searching first for the make/model number and the word "belt". If that doesn't find it, measure in MM the diameter of the belt. You might also need to measure the thickness. Put that into Google with the words "turntable belt". You don't have to spot on with the measurements. Just get the nearest to yours.
If it's a Direct Drive, then that will be an electrical fault, so it might need the attention of a trained engineer.
Mar 30, 2013 | Thorens TD-190 Turntable
Noise upon startup of thorens td 295 mk 4 turntable
Check for dirt. Try some grease or oil. Silcone grease is best.
Feb 13, 2013 | Thorens TD 295 MK IV Turntable
I need power supply for a thorens td 280 turntable 16vac. where can i order one.
Here's a parts list, but it doesn't link to a supplier.
http://www.theanalogdept.com/thorens_part_nums.htm
Power supply for:
TD 520/521/TD 290 II/295 II:
AC-Adapter, Euro standard 230 V
Z4150084
AC-Adapter, UK standard 240V without plug
Z4150087
AC-Adapter, USA standard 110V
Z4150086
AC-Adapter, Japan standard 100V
Z4150085
High End Power Supply for all units with 16/18 Voltage
9999175
This is the Thorens Service Warranty link:
http://www.thorens.com/support/service-warranty.html
This is the Service partners (post warranty) U.S.
http://www.thorens.com/support/distributors.html
Distributor United States:
Address: WS Distributing, LLC
3427 Kraft SE
Grand Rapids, MI 49512
Phone: +1 616-885-9809
Fax: +1 616-885-9818
Email: tmyerswsdistributingcom
Website: www.wsdistributing.com
This is the Thorens Homepage Technical Database for the TD280
Downloads are NOT free.
http://tech.thorens.com/en/thorens.index.php?id=en_650_0_1_&name_search=td280&category_search=1&prodd_search=0&x=4&y=7
Someone there should be able to help you out.
Dec 31, 2010 | Teac Audio Players & Recorders
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
Easrly stop
You will have to disengage the mechanical switch off lift. Pretty nice for an automatic turntable.
Keep me posted.
Oct 21, 2007 | Thorens TD-190 Turntable
947 people viewed this question
Top Thorens Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
