Heating & Cooling Logo
Posted on Apr 15, 2013
My honeywell thermostat screen went blank. Is there a reset button?
korrie_mccli
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Apr 16, 2013
korrie_mccli
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
13163
Points
44
There is no reset, and this always seems silly but have ou replaced the batteries? I've been to too many service calls for thermostat batteries!
Chronotherm 4 plus
change the batteries in the thermostat
HONEYWELL RTH230B Display is Blank. This thermostat has worked great for over 3 years. Batteries are good. But today, when the thermostat is in the HEAT position, the display is blank. When the switch is...
I had blank screen also. I placed my screwdriver between the battery terminal and battery tab and voila the screen turned on. I removed the batteries, pulled the tab out, replaced the batteries, and the thermostat is working like a champ again.
I have a Honeywell Thermostat 32207445-001 and the screen is blank. The cover indicates it may be a security feature. How do I reset the unit?
Did you try turning off the power to the unit. Also is there a lock on the thermostat. Check manual maybe you need to hold certain buttons to unlock.
Honeywell t stat rlv430 need to program to turn off every day at 700 am lower temp to 62 and on at 730pm raise to 70. need instructions on how to reset
WARNING: When the thermostat is reset, all parameters (clock, configuration
and schedules) return to their default settings.
?? Open the thermostat's door.
?? Press and hold the Pgm button.
?? Insert a pointed object (e.g., paperclip) in the reset opening.
Remove it when the thermostat's screen becomes blank.
?? Wait one second and release the Pgm button.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1855.pdf for complet instructions
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    3helpful
    The thermostat worked correctly for months then
    Go to honeywell.com
    Under red welcome sign
    Bottom red highlighted box literature/image search
    Type in thermostat model number
    Click on arrow to right
    Then click on the PDF files owners manual / installation instructions
    If you can’t find what you want, the bottom left and bottom of web
    Page, they have homeowners assistance and Home products to get the help you need
    1helpful
    Honeywell thermostat t8400c intermittent blank screen
    It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
    Screen is blank but system will run does it have a
    Check the battery. sometimes the stat can get an electrical shock, take the stat off the wall take out the batteries, if applicable, and set the stat down and walk away for at least 5 minutes then put it back, it might reset.
    1helpful
    New batteries ...display not working
    remove the batteries and pull the metal tabs at each end stretching out a little the reinstall the batteries
    Top Heating & Cooling Experts
    Paul Carew
    john h
