Question about Intel Computers & Internet
Upgrading System. I`m having C2D 1.8 GHz + Original Intel 945GC Motherboard. I want to upgrade my system in minimum cost. So that my system can work faster. Pls advise.
  • anishrajyagu Mar 10, 2009
    Thnx for your reply but i already have 1 gb ram.
  • David Shaub May 11, 2010
    Add as much RAM as you can use. Do not add extra, it will slow you down. Run full virus, malware & registry scans too.
  • 167 Answers
Http://ark.intel.com/chipset.aspx?familyID=28994 hello, i would replace the 1.8g cpu- go 2.2 or higher,then do another gig of memory. this will make it very fast. compared to now. check e-bay for cpu deals.(as these cpu's are still a little costly new) i got one-as an upgrade for my intel 2.6 965 chipset a few months ago, now at 3.2g. nice upgrade no problems. i hope this helps you, good luck! if you need help post again.
Posted on Mar 11, 2009
How to uppdate from Windows Xp into Windows7 I
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
May 27, 2011 | Intel Motherboard
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Hi, my laptop don't have any problem, but my question it is. if want i install windows 7, but 35 bits, will i can do it?
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Is a wonderful site that details the specifics of what a laptop needs to run windows 7.
Basically for the 32 bit system you need 1 ghz processor combined with 1 gb of ram and a 15-20 gb hard drive. Most laptops are well equipped to run windows 7 and some, so you should have no problem upgrading it.
Feb 07, 2011 | Computers & Internet
Upgrading CPU
Probably nothing. If your system works, I would not concern myself greatly with this small detail. The system indicates a 3.4 GHz cpu installed. Your software may misidentify some of the features of your Prescott.
Dec 14, 2009 | Gigabyte GA-8IK1100 Motherboard
Do i have to face any heating problems with the mentioned config?
If you are NOT going to overclock the CPU and memory, it should work easy.
New C2D processors are quite cool.
Also you shoult pay attention to a good Power supply, and maybe enough big case with place for front and rear extra fans,
If you face heating problems later, you may put those two fans.
Regards.
Mar 27, 2009 | Intel DG31PR Motherboard
Is it worth replacing pentium 4 1.7ghz with 3ghz one
The 3 GHz socket 478 processor will cost you about $90 shipped. Not worth upgrading for that cost in my opinion, when you can buy a whole new computer for $400 new, or a much better computer for 1/2 that used.
Mar 20, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Net Getting Disconnected
call your internet service provider, I believe that the problem is with them for loosing your connection.  They can help you set your connection.
Mar 10, 2009 | Computers & Internet
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
UPGRADING TO 2 GHZ
1. Check user documentation for supported CPUs for your system.
2. If 2.0GHz CPU is supported on your system, you don't need any additional software.
3. I would upgrade the BIOS firmware first. It might have an additional CPU support.
4. Read information from you old CPU. Exemple: 1.4GHz/256/400. 1.4GHz is a speed of your CPU. 256 is a 256k cache, and 400 is 400MHz BUS speed. In general you can boost speed to 2.0GHz or more and cache to 512k, just keep your BUS speed to 400
5. Post your system model or your motherboard model. That information would help in determining the maximum speed of the CPU for your system.
Good lick!
Jun 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Cpu upgrade dell dimension 5100
Hi, according to the Dell website you have a LGA775 socket on your motherboard. Therefore, you can only buy processors that fit into this socket. Here is a list of some offered by Intel that will work: Celeron D 325 2.53 GHz Celeron D 330 2.66 GHz Celeron D 335 2.8 GHz Celeron D 340 2.93 GHz Pentium4 520 2.8 GHz Pentium4 530 3.0 GHz Pentium4 540 3.2GHz Pentium4 550 3.4 GHz Pentium4 560 3.6 GHz Pentium4 570 3.8 GHz The processors that won't work are the ones that are not compatible with this socket. Everytime you look up a cpu it will tell you which socket it is designed for. To buy a cpu you will need to decide: The brand you want. The speed of the cpu that you want. Extras i.e. Hyperthreading, etc. How much you are willing to pay for it. Then you can narrow your search as you stick within your limits. Let me know if you have more questions. Good Luck
Sep 30, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
