Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Need part# for the following HP part: plastic power button. See it here: http://s645.photobucket.com/albums/uu171/digitaltripper/Parts/?action=view¤t=PDR_3959.jpg
  • digitaltripp Mar 10, 2009
    No I did that and they sent....The switch. I do not need the switch. I need the plastic peice shown in the link above (copy and paste into your browser address bar to see what it looks like) that pushes the actual power switch. This plastic peice snaps into the front bezel and glows blue when the pc is on.
    Scholar:
  • 73 Answers
Go to this website.
There is a number you will have to call them and ask if they have it. they have part number for a power switch assembly, for the A1330N but you will need model #. there are 2 possible.
Hewlett Packard (HP) PC / Server Miscellaneous
(5189-3960)
Hewlett Packard (HP) PC / Server Miscellaneous: On/off power switch assembly
Type: Factory Direct Price: $10.00Be aware this same part number will fit several different models. They do this to save on production costs.
Hope this helps.
Posted on Mar 10, 2009
Printer will not come on when pushing the power button
The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 17, 2010 | HP PSC 1315 All-In-One InkJet Printer
Photosmart c6180 repeatedly turns off about every 10 seconds
Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Where can I get a hp pavilion a520n power button switch?
ebay.com ;)
or you can try compusa.com
if that doesnt work just call 1-800-711-2884 HP tech support number and ask them ;)
Apr 23, 2010 | HP Pavilion A520n (DW233A#ABA) PC Desktop
HP Officejet 8500 Wireless All-In-One Control Panel Faceplate Err
>the error says it, what you need to do is check if the faceplate the plastic thing which covers the printer buttons is attached firmly.pry open the side of it rmove the faceplate then attched it back again.
Sep 24, 2009 | HP Officejet 4355 All-In-One InkJet...
Wont print error message 165:hw_interrupt_hwv2.c also 0xb9000001
The error is indicative of a hardware error.
Remove the power cord, hold # + 6 (semi-full reset) or # + 9 (full reset) buttons, then connect the power cord again, wait 3 secs (or until "Initializing Full Reset" appears on the printer display) and release the buttons.
This will set the printer configurations to its factory defaults.
Reset: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 3
Underware menu: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 4
Clear and reset NVM RAM: Press and hold OK and Cancel while plugging in the power cord.
If none of those work, it will need to be returned to HP as a failed unit.
May 31, 2009 | HP PSC 2355 All-In-One InkJet Printer
Will not print through wi-fi connection.
If this is the L7780
I had the same problem at first
Do not follow instructions in book
use inserted large sheet with set instructions
Basically
Do not temporarily connect the device to an available port on the network hub
Hit OK button on the HP control panel
Menu comes up
Then hit plastic "Setup" button below the screen
My Linksys broadband router has a "Secure Easy Setup" button
do not push this button, only use the HP screen on the printer to finish setup
May need to disable antivirus software
and Disable "Network Magic Software" if you have the program
Dec 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Broken power button on HP pavilion desktop
ok check this out, follow the two wires that come off the power switch to the motherboard, just take a flat head screwdriver and touch those two pins together and your pc will boot up. and to fix this all you have to do is go to your local pc shop (not some place like bestbuy) and ask them for an atx power switch, its an easy fix, if it doesnt fit exactly there is always hot glue.
Dec 13, 2008 | HP Power button/LED board kit with LED...
Power on button for hp a305w
Here is a manual that explains how to remove the front bezel. Please follow only steps 1 - 8 and 14 - 18. The rest of the steps are not necessary for this issue.
http://h10032.www1.hp.com/ctg/Manual/c00225826.pdf
After you have the front bezel disconnected, I would suggest checking the button on the bezel for debris that may be blocking it from making good connection (ie. dust or fuzz) which can be cleaned by a vacuum cleaner hose or compressed air can.
This may also be a good time to test and see if the actual button on the case works correctly with the front bezel removed. You will need to follow steps 17 - 18 to reconnect the machine to power. You should see a small metal button in the lower center of the case that should be the power button. It may be somewhat recessed so you may need to press it with a pencil or something. If you have trouble finding this, you can lean the bezel against the chassis and you should be able to locate it by matching where the power button is on the bezel to the chassis.
If the machine starts ok, you will need to let the machine start completely and then do a normal shutdown using the Start button and choosing Shut down or turn off depending on your operating system. After you have verified that everything is OK with that, follow steps 1 - 2 to disconnect from power again.
Now you should be able to follow steps 14-18 to put the side and front back on and connect to power.
Thanks
Jul 16, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
