Question about Sabrent (SND-P8CH) Sound Card
Computer will not complete reboot after installin card
With new card installed the computer will get to a point and the screen goes blank I removed the card and the machine works fine
    Scholar:
  • 142 Answers
I think you answered your own question. It's time to go shopping for a new sound card, and if the same thing happens then you have a problem. mysleuth
Posted on Mar 10, 2009
Pavilion dv3 power on and off continous and screen blank
Computer Keeps Rebooting - cannot access Safe Mode
1. Boot up with Windows installation CD 2. It will give you the option to use RECOVERY CONSOLE 3. Type chkdsk to check disk - this fixes bad blocks and moves data to another area. 4. When completed, remove Windows installation CD and reboot computer
Mar 01, 2013 | HP Pavilion Dv3-1075us Notebook
Screen not displaying anything. BUt the machine is on.
1.Diagnose the problem with your computer. Watch the screen from the moment you hit the power button through the time it should take to boot into the Operating System. Adjust the computer's contrast and brightness through their full ranges to make sure that the display settings have not been changed. Reset the computer's LCD-External Monitor display with the LCD/External Monitor key combination and reboot the computer. Continue to Step 2 if the screen is blank throughout the booting process.
2.Adjust the screen from its fully closed position to its fully opened position. Watch the monitor for any change from a blank screen to a display or vice-versa. If the screen flashes or cuts out, the LCD panel will need to be replaced. Skip to Step 5.
3.Skip this step if your computer does not have an external monitor output. Connect your computer's external monitor output to a known good monitor and change the display from LCD to External Monitor (the keystroke combination is different for all notebook brands). Reboot the comptuer, if necessary. If the computer does not display to the external monitor, the video card could be bad. Skip to Step 6.
4.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's LCD if you are not knowledgeable in that area. Purchase a compatible replacement LCD and install it yourself, or pay a professional technician to do so if you do not feel comfortable performing the repair.
5.Verify that the monitor connection cables are not loose or disconnected before attempting to replace it. Replace the monitor yourself by removing the old monitor. Remove the hinge covers by gently prying them. Check if they are screwed to the computer before prying. Find the monitor cable's connection to the motherboard. Turn your computer over and remove any plates that may cover the point of connection. Note the orientation of the cables before disconnecting them. Unscrew the monitor from the hinges and gently detach it from your computer. Feed the new LCD panel's wires through the same path as the old wires, and reconnect them. Secure the new LCD's hinges and replace the hinge covers. Power up the computer and check that it works. If it does not, recheck the wire connections.
6.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's motherboard or video card if you are not knowledgeable in that area. Purchase a compatible replacement motherboard or video card, and install yourself or pay a professional technician to do so if you do not feel comfortable performing the repair.
7.Replace the motherboard by disassembling the computer. Document every connection and be sure to retain all screws and small parts in order to reassemble the computer correctly. Reassemble the computer and power it up; check the keyboard to make sure that it has been reconnected properly. Replace the video card by removing any covers or plates that hide the card. Remove the old card and install the new card in its place. Power up the computer to test the display.
Sep 27, 2011 | Computers & Internet
When starting up just get black screen?
Sep 05, 2011 | Dell Vostro 1500 Notebook
My hp laptop dosn't move in configuring 3 of 3 - 0%complete,and then it just switch of and on,and comes back to configuring 3 of 3 k 0% complete
Vista Update Stage 3 Stall……
You see Installing Updates Stage 3 of 3... 0% in Vista after you start or restart your computer and it never goes past 0%. Rebooting the computer doesn't change it. It still boots to Installing Windows updates 3 of 3 and never goes past that 0% mark. Sometimes Windows will even reboot in some cases. I have found that this often happens after Windows updates. I have no idea why, but this seems to be a fairly common occurrence. The last one I repaired was caused by a Service pack 1 installation.
Here's what I have done to fix the 3 of 3 error.
You will be doing a System Restore from the Vista f8 startup
Since the computer your working on is probably stuck on this screen the first step will be a hard shut down.
Hold the power button down until the computer shuts down.
Restart the computer.
Tap the f8 key about once or twice per second to get the Safe mode screen to come up.
In Windows Vista there is a new choice when the safe mode selection comes up. "Repair Your Computer"
Highlight the "Repair Your Computer" choice.
Windows will act like it is going t boot up.
You will see a System Recovery Options window.
It will ask you to choose your language.
Click Next
Select your user and put in your password. (leave blank if you don't have a password)
You should now have choices and the one you want is "System Restore"
Follow through the prompts with the Vista System Restore program.
Remember you should pick a restore point that is 1 or 2 points back.
Once you have completed the system restore process you will be asked to restart your computer. Go ahead and restart the computer. It should start correctly at this point. If you don't have a restore point available you may not be able to repair this error. I have not tried to repair one of these without a restore point yet.
Aug 12, 2010 | HP Computers & Internet
Blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
May 03, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Sierra Wireless Compass 597 after install Vista will not reboot.
your vist disc can be booted ontop of Xp if your tower is running when your screen goes blank do you have a grafics card installed you may need to disable this back to default in bios setup
Jan 24, 2009 | Computers & Internet
Screen goes blank on Log on
You must uninstall your previous video card drivers before installing the new card, especially if they were nVidia drivers.
Jul 23, 2008 | IBM NetVista PC Desktop
Use PC wizard (search and download) this will detect all drivers needed on your computer note name and number for your video card type into search engine IE ati x300 drivers for your operating system xp vista you should be able to download correct drivers
if does not work for you please leave reply what happens
Jul 23, 2008 | HP RADEON X300 SE, (128 MB) PCI Express...
NX 6800 GT Driver issues
Either your graphics agp slot needs the driver updating or the card itself is faulty, check the agp slot for dust and gently moneuvre the card in the slot to see if the lines appear to change and check that therea are no bent pins in your connecting plug or card.
Nov 17, 2006 | MSI NX6800GT-T2D256E GeForce 6800GT, (256...
Sabrent (SND-P8CH) Sound Card Logo
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
