Question about Intel D845GVSR Motherboard
Mother board display problem
I not a have display in motherboard.clear bios by motherboard jumper then i get proper display
  • 158 Answers
You need to install the graphics driver from your motherboard CD or from internet.
After the installation is complete than just restart your machine.
It will solve your problem.
If not then
You just change your CMOS battery and then try.
Posted on Mar 11, 2009
648FX-A motherboard from EliteGroup
Turn the computer off and remove the mains power lead. Open the case of the computer and expose the motherboard. Take out the BIOS battery for 10 minutes. The battery looks like this >>>>>
There also maybe a small plastic jumper next to the BIOS battery if you look close enough it should say CLR_CMOS under it. Move the plastic jumper to the other position and push the on/off button, that will clear the CMOS.
If there isn't don't worry, just leave the BIOS battery out for 10 minutes then put the battery back in. Close the case up and the BIOS password should be cleared.
Regards.
Jul 16, 2010 | EliteGroup 648FX-A Motherboard
Tip
No Display In Motherboard
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Hope this helps,.
Thanks for using fixya.
on Jan 24, 2011 | Computers & Internet
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
HOW CLEAR INTEL D915 GAV BIOS PASSWORD
Intel mother board is very populer brand.I like it very much.If itself, It has three leg jumper near the cmos battery.1-2 short defaultor normal.2-3 short clear cmos.you like 2-3 short then fix your bios password.you must be power switch on.Un plug power cable.again jumper short 1-2 normal position. your bios clear.
Feb 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
How do you rest the bios on a ASUS p4vp-mx mother board
it has a coms jumper in side coms battery 1-2 jumper normal position 2-3 clear coms choice 2-3 then *********** board reset
Nov 22, 2009 | ASUS P4VP-MX Motherboard
I have a problem of motherboard Motherboard has power but cant come display. My friend suggest me in the motherboard jumper move it but i cant know which jumper to remove?
Jumper is a on cornor side of motherboard and is used to reset bios.....
trying to move jumper may not solve your problem .....
if u hear a tone continuesly then it will be ur ram problem..check your ram and try to fit it properly.
if there is no tone then it will be your display adapter problem..check your monitor cable..whether is properly connected with your cpu...if u have discrete graphic solution i.e. u have a graphic card on motherboard then check it if properly fitted..
if this will solve ur problem then ok..
otherwise u have to replace ur mother board..
Sep 12, 2009 | Computers & Internet
My mother board is intel 845GVSR.msg displays turn off the power and reinstall the jumper in normal mode position
Did you short the BIOS memory? In that case it hasn't been put back properly.....sodeep
Apr 18, 2009 | Intel D845GVSR Motherboard
Pc starting problem
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Mar 10, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
NO BIOS
to get bios set up you must press DELETE key or F2 to enter set up...
you do this at the time of the booting ....
if your bios is corrupted then you can restore the bios by changing the bios jumper to restoration mode to do this refer to your motherboard manual...
Feb 22, 2008 | Intel Motherboard
Intel D845GVSR Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
