Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
Help! My Kenmore Elite Quietpak2 HE3 keeps cycling off during the wash cycle with a series of beeps and then flashing alternating 06 F. Does anyone know what this code means and how to get my washer running again?
  • jmchisholm76 Mar 12, 2009
    Thanks a bunch!
  • edaoust Mar 30, 2009
    I have the same problem and now my unit has stopped and the light is on that says Controls Locked. I can't do anything and have wet clothes in the machine. Any body got an answer as to haw to unlock the control panel?
  • 360 Answers
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Posted on Mar 10, 2009
Kenmore Elite washing mahcine HE3 quietpak2 Model#110.45862404 - The selecting cycle wash button does not follow command. It is only delicte and handwash cycle wash botton is working.
Sounds like a problem in the button panel, but could be firmware is in a knot, which is an easy fix: Try unplugging machine and plug back in 5 minutes later. Then see if it works.
Jun 19, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
How can I get an operators manual for a kenmore elite quietpak2 HE3 washer?
See the following Sears site for manuals:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Residential%20Washers?query=kenmore+elite+quietpak2+HE3
You'll have to determine the actual model number and then you can download a PDF version of the manuals.
Nov 18, 2010 | Kenmore Washing Machines
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Runs fine but will not engage the spin cycle to remove water. the drum rotates but not at any great speed.
Have you solved your problem? My Kenmore Elite Quietpak2 gives me an error message HF on every wash cycle. Will not complete a full wash. Help please.
May 06, 2010 | Frigidaire Washing Machines
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
616 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
