Question about Car Audio & Video
Does the ''source ground''wire from car equalizer go to head unit or itself?
  • 27 Answers
It dosent matter ive done it both ways and they work fine with no problems
Posted on Mar 16, 2009
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
Feb 11, 2011 | Pioneer DEQ-7600 15-Band Car Equalizer
What is source ground on an equalizer
Ground Source, not the other way around. It is a metallic place, interconnected to the vehicle chassis, where the electricity will flow from positive to negative. Best bet is to connect your equalizer black ground wire to the radio black ground wire, since it has already been bolted to a good ground. Furthermore, grounding it to radio, will prevent any humming between the two units.
Jan 22, 2010 | Boss AVA-1204 7-Band Car Equalizer
No Power, need help asap!
Check your grounds! If you used any "scotch-locks" wire connectors (the kind that crimp to an existing wire to hook up another) get rid of them. have had multiple customers with issues with thoes things. remember the basic electrical circuit needs both power and ground to opperate correctly. Good luck!
Aug 21, 2009 | Pioneer DEH-P4000UB CD Player
DEQ 9200 does nothing but blink
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
Pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Oct 08, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
My car amp works produces distorded noise . As I plug in the rca cables i noticed that if just the tip of the connector touches i get a good sound but if i insert the whole connector it becomes distorded...
You have a grounding issue.
The RCA inputs of the amp are many times NOT tied to chassis ( the chassis of the car ) ground.
Same goes for the RCA outputs of your head unit.
The speaker outputs of your amp SHOULD NOT EVER be tied to chassis ground.
  • make sure that no speaker wire from the amplifier is touching or attached to ground.
  • Make sure that your amplifier ground (GND )( of the 3 power inputs.....GND, +12V, Rem) is securely mounted to a bare metal spot on the frame. Best practice is to have the amp GND, and the head unit GND at the exact same physical point.
  • Make sure that your RCA cable shield ( not the center tip, but the part around it ) is not touching the chassis.
  • Make sure that you have not nicked the wire while installing it and are accidentally getting a connection to the frame of the car.
  • Make sure that the head unit is grounded properly.
  • IF for some reason you have an equalizer between the head unit and the amplifier, make sure it has its own switching power supply INSIDE the EQ.
Bad grounds are a pain to of luck....Rob
Mar 17, 2008 | Audio Players & Recorders
Car Audio & Video Logo
256 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
