Question about Kenmore Washing Machines
I have Kenmore front loader type KWM743M
I thing the lower two springs of the barrel are gone and I have problems getting spare ones...any help...
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How do i disassemble a kenmore elite washer to get to the water pump
In a typical Kenmore top loader, screws are removed from the boittom of the control panel, allowing the panel to be rotated up toward the rear of the unit. This reveals two spring latches. Some dispenser tubing may have to be disconnected prior to removing the cabinet. The two spring latches, when released, allow the cabinet to be slid forward to expose the inner assemblies. The pump is located in the lower front.
May 09, 2014 | Kenmore 24032\24036 Top Load Washer
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
How to unclog drain hose/pump? my front loader
First of start by checking the rubber gasket seals around the door and making sure those are good and clean and dry. Then inspect the barrel itself. My daughter loves to leave scraps of paper in her pockets that then get stuck in my front loader. Clear any debris from the barrel. Does your machine have a small front access panel or back access to get to the filter? Most front loaders have some sort of filter on them apart from the barrel. If you can find this part, it is a common culprit. Mine is a tube shaped basket with a front access panel on this one. On the front loader before this one is was back panel accessable under the drum. when you check these have a bucket and some thing mop up with handy, towels, mop, etc. One other thing to consider is the drain hose from the machine. I have flushed mine using a garden hose in the yard and used a little bleach.
May 12, 2017 | Frigidaire ATF6000ES Front Load Washer
Kenmore washing machine
Whether this is a TOP LOADER, or a FRONT LOADER, the drain pump is located directly below the wash tub in the front of the washer. Accessing either one takes, different procedures, however.
To access the pump on a TOP LOADER, you must remove the exterior washer casing. Follow the steps provided in this link:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If this is a FRONT LOADER, you must remove the lower toe panel directly below the door. Follow the steps provided in this link:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The Kenmore Oasis is a different configuration from the two I've mentioned. There are two pumps on the Oasis. One is a drain pump, while the other is a recirc pump. Both are accessible by removing the rear panel of the washer.
If you require further assistance, please post back with a complete model number so I can determine how your washer is configured. I hope you find this information helpful.
Dec 22, 2009 | Kenmore Washing Machines
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
My kenmore front loader makes a knocking when it spins.
how old?sounds like the bearing are going bad,on yours the tub and bearing are one unit,so you have to change out the whole thing-mike
Mar 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore KWM743M washing machine, where to find a manual?
www.diplodocs.com has a buch of manuals.
Mar 13, 2009 | Kenmore Washing Machines
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
Replacing spring wire on kenmore front loader HE 2
This is often a very tricky process. The easiest way I know how to get the inner spring back in place is to use two sets of hands and work through the door and through the bottom panel as well. Follow these steps:
1. Remove the lower panel under the door.
2. One person reach through the door opening and insert the spring in the bellow groove, starting at the top.
3. Work the spring around to the 3 and 9 o'clock positions and hold in place by keeping your fingers on the spring in the groove.
4. Have a second person, laying on their back, reach through the bottom panel and grab the lower half of the spring on each side with both hands.
5. While the first person holds the upper portion in place, the second person pulls straight down and works the remaining portion of the spring in place.
This is the best way, I have been able to accomplish this. Make sure you use a type of applaince adhesive to reseat the outer portion of the bellow to the door frame if this is the glue on type. If you have questions, or require additional assistance, please let me know.
Jan 14, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
74 people viewed this question
Sal De
fordexpert
Robert Rankin
