Question about kawasaki Full Suspension Mountain Bike Men
Gas flooding cylinder
I have a 1987 Kawasaki Vulcan 750 today it died out.I towed it to my house and removed the spark plugs and the front cylinders were flooded. bike has been backfiring lately also. Any advise is greatly appreciated.
    Problem Solver:
  • 5 Answers
I would pull your carbs, clean them and look for wear on your diaphrams and check your floats.
Posted on Sep 02, 2009
  • vulcan750 Sep 02, 2009
    did you give it throttle while you had the choke on?
I have a 99 Kawasaki Vulcan classic one car bike why would the bike flood the back spark plugs and put gas in my air filter been trying to figure it out but I need help
Hi, Brandon my guess is you have a faulty spark plug or spark plug wire/cable or ignition coil or wiring to the coil is corrupt, check the ohm reading on your plug wires/cables for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Rear plug fouling Kawasaki Vulcan Forum Vulcan Forums
Plugs fouling and leaving me stranded Kawasaki Vulcan 750 Forum Kawasaki...
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/155449-1998-1500-vulcan-classic-fouling-plugs-rear-cylinder-only.html
http://www2.vulcanrider.se/DL/KawasakiVN1500_87-99ServiceManual.pdf
Apr 29, 2016 | kawasaki Motorcycles
Kawasaki 750 V twin rear cylinder filling up with fuel
Hi, Gary for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
1st cylinder fills up with gas anyone Suzuki GSX Motorcycle Forums Gixxer...
Cylinders Filled Gas Kawasaki ATV Forum carb issues overflow excessive fuel Kawasaki Vulcan Forum Vulcan Forums
Dec 12, 2015 | 1987 kawasaki VN 750 Vulcan
1997 Kawasaki VN 1500 Vulcan Classic the engine is only firing on 1 cylinder
Hi, Anonymous you need "FIVE" things in order for a cylinder to run properly:
1. FUEL: in order to validate your not getting fuel spray some starting fluid into the air cleaner and hit the starter button, if it fires up and runs for a few seconds then you know you have a fuel delivery issue. Multi carb banks should be bench "SYNC"
2. SPARK: remove the spark plug and with it connected to the spark plug cable ground the threads to something metal you should see a bluish white spark if not you have a faulty spark plug, spark plug cable, ignition coil, condenser, CKP, ECM, sensor or the wiring in between.
3. COMPRESSION: you must have at least 80-100 PSI for most bikes, multi-cylinder engines should be within 10-15% of each other if not perform a leak down test you may have a burnt or bent valve or hole in the piston or broken rings.
4. CAM TIMING: confirm your timing marks are aligned to see if the cam chain or adjuster are worn out and the chain has skipped a couple teeth.
5. IGNITION TIMING: on older bikes check to see if your points have not closed up, timing plate has not become loose and confirm with a timing light for proper retard and advance functions, on newer bikes where timing is controlled by an ECM and is nonadjustable check you CKP, TPS, MAP, O2, sensor or its counterpart for integrity.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Front cylinder not firing on 1500 Kawasaki Vulcan Forum Vulcan Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/102776-no-fire-rear-cylinder.html
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1997 Kawasaki Vulcan 1500 Classic Owner Manual
Jul 01, 2014 | 1997 kawasaki VN 1500 Vulcan Classic
1997 Kawasaki VN 750 Vulcan spark plug gap
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Spark Plug Gap for 1986 VN750 Kawasaki Vulcan 750 Forum Kawasaki VN750...
Plug gap Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN 750 Service Manual
1997 Kawasaki Vulcan 750 Owner Manual
Apr 19, 2014 | 1997 kawasaki VN 750 Vulcan
Front cylinder fouls
try cleaning the carbs, changing plugs, and cleaning the fuel tank. If that doesn't work, it might be the piston rings are getting worn out or you cylinder sleeves need a honing.
Jan 15, 2014 | 1994 kawasaki VN 750 Vulcan
1986 Kawasaki VN 750 Vulcan gas coming out of the exhaust
Hi, Anonymous and the usual suspects are:
1. Fouled spark plug.
2. Fuel injector stuck open.
3. Carburetor float needle valve, not seating.
4. Carburetor float stuck open.
5. Exhaust valve stuck open.
6. Exhaust valve bent.
7. Fuel valve leaking back through the vacuum line.
fuel leaking out my exhaust Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
Raw Gas Coming Out Exhaust Kawasaki Vulcan Forum Vulcan Forums
1989 Kawasaki Vulcan 750 Owner Manual
Jul 31, 2013 | 1987 kawasaki VN 750 Vulcan
Why does my 1995 Kawasaki VN 750 Vulcan have four spark plugs?
Hi, Anonymous twin spark technology is more beneficial than using the single spark technology. Technically the spark plug has a very minute time to react and meet perfect ignition; approximately 1 by 200th of a second in an engine running at 6000 rpm. In that time the spark plug must fire and burn the engine mixture as quickly as possible. Once that cycle is complete, the cylinder must ideally be ready for the expulsion of all the exhaust gases ensuring as little unburned fuel or hydrocarbons as possible. Now the main problem lies in that time the spark plug has to perform its role. It might work well enough in case of a smaller engine where the gas mixture can be evenly spread out in no time for the spark plug to burn for good results. However as the engine size goes up especially as in the case of race cars and performance vehicles, a single spark plug will not have the time to burn through all corners of the chamber. The matter is further complicated by the fact that engines aren't static and the burn must start off at the top dead center and process down to the bottom dead center with the piston descending rapidly.
Why 2 plugs per cylinder Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
How To Vulcan Motorcycle Spark Plug Change
1995 Kawasaki Vulcan 750 Owner Manual
Mar 22, 2013 | 1995 kawasaki VN 750 Vulcan
1987 Kawasaki VN 750 Vulcan spark plug type
Hi, Tony for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
http://www.vn750.com/forum/47-maintenance/1162-spark-plugs-wires.html
Kawasaki Vulcan 1500 Specs Kawasaki Vulcan 750 Parts
Feb 21, 2013 | 1987 kawasaki VN 750 Vulcan
1996 Kawasaki VN 1500 Vulcan Classic no spark on rear cylinder
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
No Spark at Rear Cylinder Only Kawasaki Vulcan 750 Forum Kawasaki VN750...
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Sep 05, 2012 | 1996 kawasaki VN 1500 Vulcan Classic
1987 Kawasaki VN 750 Vulcan oil change
Oil Change Procedure Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
How to change motorcycle oil Kawasaki Vulcan
Jun 29, 2012 | 1987 kawasaki VN 750 Vulcan
kawasaki Full Suspension Mountain Bike Men Logo
167 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
