Question about Gateway Solo 9550 Notebook
My apt. complex offers a shared computer. The
My apt. complex offers a shared computer. The sound willbe disabled when i log on. I often can get sound working by unmuting,orby plugging the speakers back in or rebooting the system, but this time I can't find how it was disabled. please help.
I get error #1303 and am told to sign in as Administrator, however, I am the only user and am signed in as Administrator. I am trying to install my WordPerfect Office X4 on my laptop after a successful...
If I remember correctly, you get the advanced file sharing and security when you enter safe mode in windows xp home. Try safemode - tap f8 in start. startup in safe mode, you should be able to edit the permissions of the folder its lacking permissions to.
let me know how it goes.
Sep 27, 2008 | Computers & Internet
Set up a computer-to-computer (ad hoc) network
An ad hoc network is a temporary connection between computers and devices used for a specific purpose, such as sharing documents during a meeting or playing multiple-player computer games. You can also temporarily share an Internet connection with other people on your ad hoc network, so those people don’t have to set up their own Internet connections. Ad hoc networks can only be wireless, so you must have a wireless network adapter installed in your computer to set up or join an ad hoc network.
Click to open Connect to a Network.
Click Set up a connection or network.
Click Set up an ad hoc (computer-to-computer) network, click Next, and then follow the steps in the wizard.
If one or more of the networked computers is joined to a domain, you need to have a user account on that computer to see and access shared items on it.
If the networked computers are not joined to a domain, but you want to require people to have a user account on your computer for access to shared items, turn on password protected sharing in Network and Sharing Center.
To turn on password protected sharing
Click to open Network and Sharing Center.
Under Sharing and Discovery, if password protected sharing is off, click the arrow button to expand the section, click Turn on password protected sharing, and then click Apply. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
An ad hoc network is automatically deleted after all users disconnect from the network or when the person who set up the network disconnects and goes out of range of the other users of the network, unless you choose to make it a permanent network when you create it.
If you share your Internet connection, Internet connection sharing (ICS) will be disabled if you disconnect from the ad hoc network, you create a new ad hoc network without disconnecting from the old ad hoc network for which you enabled ICS, or you log off and then log back on (without disconnecting from the ad hoc network).
If you set up an ad hoc network and share your Internet connection, and then someone logs on to the same computer by using Fast User Switching, the Internet connection will still be shared, even if you didn't intend to share it with that person.
I hope you all found this information useful and helpful.
on Jul 31, 2010 | Computers & Internet
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
on Feb 24, 2010 | Computers & Internet
What is WPS button?
The WPS is abbreviation for Wi-Fi Protected Setup. This function should you help to set up strong wireless network password (so called "shared secret") by very easy way.
For most of users is very hard to create, remember and assign complex long password to Wi-Fi router and client devices e.g. smart phones, laptops, printers.
Short and simple (non-complex) password is weak and can be broken by hackers. You can set strong password using WPS buttons. No device management access is required.
Procedure description
Press WPS button on both devices you wish connect each other. (Router, wireless printer...)Wait until password is set automatically and devices are connected.There exists second procedure in WPS standard. It is similar to described one, but PIN number is required in addition.
Security warning!!!
Enabled WPS function is very high security risk. The WPS sets strong password, but offers another security hole to hackers. The WPS standard is affected by well known vulnerability and therefore is insecure. It is recommended to DISABLE WPS ON ALL DEVICES. Go to device setup and disable the WPS completely.
Jan 28, 2016 | Computers & Internet
Some one in my apt. complex has started using my wifi and now I can't add a lap to my connection. How can I change my password?
Ramona, try turning your wi-fi router off then back on. do what you need to do to add your lap before whomever logs back on. if this works, get back here and we'll see what we can do about your password k/
Feb 02, 2015 | Dell Computers & Internet
What to do if this is coming in between ( gzip.exe has stopped working) ?
re-install gzip if this is for ubuntu
type sudo apt-get remove gzip this removes it
sudo apt-get update
then run
sudo apt-get install gzip
this re-installs it then log off and log back in and see if you get the same error.
Jan 25, 2012 | Microsoft Computers & Internet
Lost paperwork to my berklin wireless router, need to know how to put a security password to log on. i live in an complex and there are some people i believe are hacking in. my computer is new and running...
Hi here is the answer if you want to setup wpa/wpa2 security then follow the below seps
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Sep 26, 2010 | Computers & Internet
Open Questions:
See all Gateway Solo 9550 Notebook Questions
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
