Question about HP G60-120US Laptop
Internet connection i was messing around with the network and now i can connect networks but i somehow blocked the internet. Does someone know the ropes of the networking and internet connections? i can connect to a network but im blocked from the internet. please help anybody experienced.
  • roelm07 Mar 10, 2009
    System restore will surely help the problem but i have windows package's and other stuff installed that i really cant install again because my uncle used his cd's to install it.
I had the exact same problem, all you need to do is do a recovery, you proberly won't need a cd because i didn't but even if you do then they are easy to make
Posted on May 13, 2009
    Problem Solver:
  • 12 Answers
I would recommend you to do a system restore on your computer.
I hope that fixes your problem!
Posted on Mar 10, 2009
  • edwintech Mar 10, 2009
    This will reset network settings to its state that existed when the operating system was installed
    1. Go to Start -> Run -> Type "cmd" and hit Enter.
    2. In the command prompt type the following: 'netsh int ip reset' and hit enter.
    3. You will need to reboot your computer after typing this command.
    I also recommend doing the following after rebooting your computer:
    2. In the command prompt type the following: 'netsh winsock reset'
I can't connect to the internet. How can I connect to the internet?
01
of 10
Are You Overlooking the Obvious?
Unplugged or loose network cables are easy to miss yet one of the most common reasons you might suddenly find yourself unable to connect to the Internet. That's not a problem on wireless networks, but on most laptops the Wi-Fi radio can be inadvertently shut off instead. On home networks, it's also possible someone unplugged the router.
Action - Ensure your wired or wireless network hardware is switched on and plugged in. 02
of 10
Rule Out False Alarms
What may seem to be a network problem connecting to the Internet is sometimes simply a Web site (or whatever server is on the other end of the connection) being temporarily offline.
Action - Before assuming your Internet connection is faulty, try visiting several popular Web sites rather than just one. 03
of 10
Avoid IP Address Conflicts
If your computer and another on the network both have the same IP address, the conflict between them will prevent either from working properly online.
Action - To resolve an IP conflict, follow these instructions to release and renew your IP address. If your network uses static IP addresses, manually change your IP to a different number. More » 04
of 10
Check for Computer Firewall Malfunctions
Firewall software running on most computers is intended to prevent unwanted network traffic from disrupting its operation. Unfortunately, these software firewalls can malfunction and start blocking valid Internet traffic. When two software firewalls, such as Windows Firewall plus a third-party product, are installed on the same computer, contention between the two can also incorrectly block traffic.
Action - If you've recently installed or upgraded software firewalls on your computer, temporarily disable them to determine whether it may be the cause of Internet connection problems.
05
of 10
Are You Outside of Wireless Signal Range?
The performance of Wi-Fi network connections depends on distance between the device and the wireless access point. The further away a Wi-Fi device, the slower the local connection generally runs, until it breaks altogether. Wireless signal interference in the area can also limit the effective range of a Wi-Fi connection. Whenever you're unable to reach the access point, you also can't connect to the Internet, obviously.
Action - Use one of these options to measure the strength of your wireless signaland try these ideas to expand the range of your Wi-Fi.
06
of 10
Has Your Wireless Network Configuration Changed?
Wi-Fi networks with encryption options like WPA or WEP turned on require computers to use matching security keys when connecting. If someone changes the encryption keys or passphrase on the access point, devices that worked before will suddenly be unable to establish sessions and Internet connections. Likewise (though less likely), if the access point settings are changed to require using a specific Wi-Fi channel number, some computers may be unable to discover it.
Action - Confirm the Wi-Fi channel number and encryption keys on your router have not recently changed (check with the network administrator if necessary). When using a hotspot, follow the provider's instructors for signing on carefully.
07
of 10
Check for Broadband Router or Access Point Malfunctions
Home networks that use broadband routers are easier to manage than those without one, but technical glitches with the router can also prevent computers from connecting to the Internet. Router failures are caused by overheating, excessive traffic, or simply an older unit going bad. Typical symptoms of a flaky router include computers on the network not being able to obtain IP addresses, or the router console not responding to requests.
Action - Check the router's lights and console if possible to ensure it is running and responding properly. Troubleshoot and reset the router if necessary.
08
of 10
Are You Being Blocked By Your Service Provider?
Internet Service Providers (ISPs) can choose to block access from your account if you fail to make payment or otherwise violate the provider's Terms of Service. Especially when using paid hotspots that charge by the hour or day, sometimes people forget to keep their subscription updated. Other common reasons an ISP might block your account include exceeding bandwidth caps, sending spam email, and downloading ******* or inappropriate content.
Action - Contact your ISP if you suspect your account has been blocked.
09
of 10
Cope with Computer Glitches
Computers, too, suffer from technical glitches. Although relatively uncommon nowadays, a computer's network adapter hardware might suddenly fail due to overheating or age. Failures in the operating system software that control the adapter, on the other hand, can occur frequently especially with computers that are heavily used. Viruses and worms also may disable or block a computer's network interfaces from functioning properly. Finally, if using a laptop or other mobile device, transporting it from one location to another can corrupt the state of its network.
Action - Check the computer for malware and remove any found. On Windows computers, try resetting the network connection. Reboot the computer if necessary.
10
of 10
Contact Your Internet Service Provider
Those using satellite Internet service may notice they can't connect to the Internet during periods of very bad weather. Providers in dense urban areas (including cellular Internet carriers) sometimes are unable to support peaks in network traffic that causes sporadic outages for some customers. Finally, those who subscribe to newer or more complex forms of Internet services (such as fixed wireless broadband) may experience more downtime than others as providers encounter more issues with relatively less mature equipment.
Action - If all else fails, contact your Internet provider to verify whether they are experiencing an outage. Some providers also give advice on troubleshooting problems connecting to their network (sometimes for a fee 12 Tips for Troubleshooting Your Internet Connection
Feb 05, 2018 | The Computers & Internet
My samsung dvd smar hub player just recently somehow disconnected from the internet and I would like to know how to reconnect it. Nothing seems to work.
No knowing what you have tried I will make suggestions. Do your other internet devices work? Check the network setup on the player. See if the connection is being blocked by a security setting. How is the player connected to the internet? If wired make sure the cable has not come disconnected from the router or device. Make sure the cable is good by connecting a device that uses the internet, like a laptop or run a test cable. If it is wireless see if it has a good signal.
Jun 12, 2016 | Samsung Televison & Video
Emachines t3418 no wifi connection
do you have wifi adapter (wifi dongle/wifi modem) in your computer if no you have to buy it
Jul 16, 2017 | Computers & Internet
My Ubuntu Linux laptop computer somehow got disconnected from the wireless network and when I click on the Network Manager Icon, wireless connection is not highlighted and it says it is disabled. I do not...
Could you have disabled the internet connection? try clicking on yhr control panel and checking your internet connection there, click on"set up or change internet connection, be sure thatin the connections tab you have your information in the box
Feb 04, 2011 | ValuSoft Ubuntu Linux for PC, Mac, Linux
NEED HELP FROM ANY EXPERT OUT THERE! MAKE MY WELCOME SCREEN WORK!
Hi, you need to right click on your local area connection, then go to properties and uninstall the protocol from there.
May 30, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
I keep getting error 80710092 cannot connect to playstation ntwrk
There is a possiblity that someone else using ur internet access was caught hacking, and got your internet service blocked.
Mar 21, 2009 | Video Game Consoles & Games
Moto q9h does not connect to the internet my q9h use to connect to the internet with no problem until today. it says could not establish a connection please check your conn. settings. does anyone know the...
i found the connection settings. somehow they got messed up but here they are.
in GPRS: connects to: The Internet. clear the username and passwords.
in Proxy: connects from: The Internet. connects to: WAP Network. Authentication (i think) HTTP
that fixed my problem and also in Opera, settings uncheck the box and put in on WAP Network.
turn off for two minutes, then on. this fixed my problem. i called at&t and they were able to help me.
very fortunate, this phone is awesome!
Dec 13, 2008 | Motorola Mobility Q9h Smartphone
Somehow my own wireless connection is not being recognized. I noticed my speed is at 54mps and not 100%. I am hooked up to another Linksys and my computer is running very slow. When I see my own connection...
HI,
Thanks for responding. To me, my router was running before at 100 mps. I took a better look and someone, somehow has tapped into my computer. My computer tends to stop working in browsers and I keep getting notifications to block access. My own router is showing, however I cannot access it. I will have to refresh my network, and reenter my own network and get that creep off my system.
Thanks for your help.
Dec 02, 2008 | Computers & Internet
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
HP G60-120US Laptop Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
