Question about Bose 3·2·1 II System
My bose 321 won't play DVD only CD
When i load a DVD it only say loading for about 5 minutes and then it will say no disc insert disc
Your problem is very easy just open the unit and replace a new one lens or maybe if you dont understand just text me and i help you without any cost 09202838700 challenger3_73@yahoo.com
Posted on Mar 10, 2009
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
Insert dvd but comes back saying no disc inserted
Hello
Your DVD players loading mechanism has some fault with it. It does not load the disc properly in, Check the loading belat first, and the loading motor for low pulling power. Check whether there is any fault loading gear wheels. The fault is clearly of the loading mechanism itself. OK.
May 18, 2011 | Pioneer Televison & Video
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
I put a DVD in my Digitec DVD player. it says Loading for about 2 minutes and then says no disc with all dvd's but it worked less then 24hours ago
try to open the case of your DVD player, insert the DVD disc and then see if the disc is spinning and loading, otherwise the optical DVD laser lens is weak.. you have to replace it.
Aug 14, 2010 | Televison & Video
Problem with 'loading'
that is the laser lens , it is dirty,
you will have to cleaned use a q tips with wood alcool
dont aply to much pressure on it while wiping it
its should works if it not
that is the laser it self replaced the laser assembly
hope that will help
regards Alan
May 16, 2010 | Spectroniq PD-1100 DVD Player
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Jul 09, 2009 | TruTech PVS31170S1W 17 in. LCD Television
"loading" message appears several minutes, then "no disc" message
check another disk.
or your dvd lens is weak to read dvd
i think it can read cds now.
if not, try to update firm ware or your dvd.
Jan 17, 2009 | Televison & Video
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Bose 3·2·1 II System Logo
582 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
