Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Pc starting problem
When i clear the bios by jumper my mother board will be started and after i plug out the power and mother board is not starting again bios clear then started
  • 2,794 Answers
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Posted on Mar 10, 2009
  • PENDURTHI BHASKAR
    PENDURTHI BHASKAR Oct 26, 2013
    SIR ICHANGED THA BATTERY NO USE
I can't find the jumper on my dell inspiron b130
Hi,what type of jumpers do you mean? if you want to clear your bios you can use jumpers calls "CLR-MOS" or "CL-ms" or "cms_clr" that it means CLEAR CMOS or CLEAR MOS (stands for mosfet transistors built in mother board eeprom" you can clear it this way:
shutdown the pc or laptop find the jumper pull the backup battery up use a screw driver or an iron pin to short the jumpers together(if you dont find the jumpers after pulling up the battery short the battery+- together) wait 10 sec and then pull in the battery after that you have to go to your bios setting and set some data if you dont you may see errors like this in your screen before windows start up:
"DMI POOL DATA CHANGED" PRESS F1 TO continue" or something like that;
and if you dont know the bios setting ask from experts to do it for you because this setting is too dangerous and may harm your hardware,if you dont know dont touch it,
and one more thing:
if you mean another jumpers?dont touch it because some mother boards use jumpers for their settings or you may harm your hardware
kind regards
Apr 18, 2013 | Computers & Internet
When i start PC; BIOS seting opens and says clear
  1. pls read the user manual first to identify which pinds of password jumper to normal position
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your computer'sservice manual.
Aug 23, 2017 | Intel D102GGC2 Motherboard
What is optiplex gx 260 pc's default bios password?my pc ask a bios password,but i never enable bios password.
Here are some important links from which you can get the easy steps and your solution.So please visit the below links and I am sure your problem will be solved
http://www.computerhope.com/issues/ch000235.htm
http://www.computerhope.com/issues/ch000451.htm
http://www.dewassoc.com/support/bios/bios_password.htm
Please rate me if this solution works for you
Thanks......Have a great time
Jun 28, 2010 | Dell OptiPlex GX260 PC Desktop
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
HOW CLEAR INTEL D915 GAV BIOS PASSWORD
Intel mother board is very populer brand.I like it very much.If itself, It has three leg jumper near the cmos battery.1-2 short defaultor normal.2-3 short clear cmos.you like 2-3 short then fix your bios password.you must be power switch on.Un plug power cable.again jumper short 1-2 normal position. your bios clear.
Feb 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
Power
Hello
If you're replacing a motherboard then the new motherboard has a jumper across the on/off jumpers. If this is used board then check to make sure the on/off jumper pins are not shorted. If OK boot up and go into BIOS. Make sure that any line stating Automatic Turn ON is off.
Sep 24, 2009 | Intel PGA478 Motherboard
I have a desk pro 4000 with windows profesonal installed on it it has locked on a password and will not bypass start up what can i do ????
With most pc's there is either a switch or a jumper situated on the mother board, power down pc, move jumper to alternative pins, or flip switch then power on then off, put jumper/switch into original position bios password is now cleared. for jumper switch configuration should be on inside of pc cover or in your manual
Sep 10, 2008 | Compaq Computers & Internet
I can't access my BIOS in my toshiba computer
Assuming this is a desktop and when you say you can't access it because of a password, there is a solution.
-Unplug your computer
-Press the power button to release all power in the capacitors
-Open up the case
-Ground yourself by touching the metal case but not the board.
-Look towards the edge of the mother board, there is usually a button or a jumper (a set of two pins with a black piece of plastic across them)
-Press the button or remove the jumper
-Plug the computer in and start it
You should be able to access the BIOS now. Once you finish, replace the jumper if needed and you are clear. You might want to reset the password in the BIOS while you are in there though.
Apr 30, 2008 | Computers & Internet
BIOS PASWORD FOR CELSIUS R 610
hi
if u dont knoe the password
u must clear it
u can your clear withyour bios
see the jumper of three pin near cmos cell
set the jumper to 2-3 position then give power too mother bord 3-5times.
then set it to its original position.
then if your pro is same by mistalke.
u can also clear it bye remove cmos cell from its case for 15 minutes.then start pc u not need to enter password.
Mar 28, 2008 | Fujitsu Siemens Celsius R610 PC Desktop
Hp d530C/p2.4obc/256E/4 uk
you can clear the cmos by removing the bettery, wait for 10 to 15 seconds then reinstall the battery. you can also clear the cmos by transferring the jumper of cmos clear from your mother board. remove the jumper from pin1-2 then transfer to pin3-4 then return to pin1-2 then power on
Dec 24, 2007 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
