Question about True 23 cu. ft. / 651 liter Commercial Freezer T-23F
    New Friend:
  • 3 Answers
The evaporator fan does not come because its connected to a defrost termination switch that's on the evaporator so first condenser fan and compressor turns on. evaporator fan will come on until defrost switch is satisfied, which is at about 40 deg.
Posted on Apr 06, 2013
  • 27 Answers
Fan burnt or relay fauly or fuse blown
Posted on Mar 10, 2009
Ice build up in refrigerator
Ice build up is either obstructed air flow. Too much stuff in the freezer. The freezer evaporator fan is not working or the defrost system is not working. Check obstructions to air flow first and see if the fan is running. If the fan is not running, you mostly likely have a dead fan motor. Not an easy fix for average person.
Jan 06, 2014 | Whirlpool Stainless Steel Top Freezer...
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
True freezer model t -23f need wiring diagram
There is a safety cutout on the evaporator that sometimes goes open circuit, stopping the heater coming on in defrost.If the compressor will not turn off, check the condenser is clean.and the fan working. next check the thermostat hasn't broken. Lastly, check the defrost timer.
Dec 27, 2012 | True Freezers
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
I turned the power on my freezer as now we decided to use it , before it was working fine it became very hot inside and the fan on the top didnot start?
Too many things can go wrong, but try this first, The fan on the top must be turning got the unit to work. Sometimes when a unit sits up for a while the fan bearings freeze up. Try trurning the fan with your hand of a screwdriver if it has a shroud around the fan. It may start moving and ususally when it does it will be arright after that. The inside will be hot because it will go into a defrost cycle 3 or 4 times a day and that puts a lot of heat inside the unit. Also the door frames are heated. Check to see if the compressor is running. If it is the small copper line going over tt the fan will be very hot. If not its not running. Co to start with clean the radiator coils on the outside and make sure the fan by the compressor is running.
Sep 17, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
True 23 cu. ft. / 651 liter Commercial Freezer T-23F Logo
467 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
