Question about Apple iPod touch
Wi-fi connection does not work
I also get full strength wi-fi connection, but cannot connect with itouch 8gb. Who can help?
  • 2 more comments
  • Anonymous Mar 23, 2009
    my itouch does show the Wifi connections when i try to connect it with Wifi
    i go to setting>Wifi> and nothing goes out even though i hve wifi connection in ma house !!
    PLEASE HELP
  • yujryu Apr 07, 2009
    my ipod catch the wifi connection but internet wont work....aaaaaaaaa
  • Anonymous May 25, 2009
    it wont work
  • Gabe Reiss Consulting May 11, 2010
    What do you mean you cannot connect with touch 8gb?
    President:
  • Apple Master
  • 688 Answers
Go to settings and wifi...look for your network and tap on it.
Join your network and if it is secure it is asking for the WEP key which is on the label of the router.
Enter that kep and it should join.
if it is truely an unsecure wifi you should be able to get right on by joining it.
You may be seeing full signal but it may be your neighbors or next door
Good Luck
Posted on May 26, 2009
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
My itouch has a wi-fi connection but it will not go on internet.
Turn on your Itouch, then touch "Settings", you will see "Wifi"...find the wifi that you want to connect to and touch it to activate the wifi.
Good Luck, I hope this helped
Please rate me
May 10, 2010 | Apple iPod touch
How do i get my wep key for my itouch
The touch doesnt have a "key" this is the key from the Wi-fi spot you are trying to connect to.
You will need the person that owns that wi-fi to provide that to you. The itouch simply connects to the wi-fi and uses it for internet.
Hope this helps.
Mar 15, 2010 | Apple iPod touch
Itouch 8gb, cannot get an internet connection How do I get connected
It has to be thru a Wi-Fi. Go to your settings and make sure the Wi-Fi is turned on. It does not access the net on it's own like a cell phone. It rides on a Wi-Fi. Check your settings be sure the Wi-Fi is on, if you have Wireless internet in your home you will have to set up the wep settings, or your router numbers.
Jan 06, 2010 | Apple iPod touch
Wi-fi connection does not work, though recognizes signal
I had the same problem. This is a router problem. If you are comfortable with going in and re-configuring some things with your router , you maybe able to repair this. Try changing the channel your router is operating on. Make sure your router is not near a telephone or other device that may operate on or near the same frequency. This could affect your ability to be a able to connect via wifi.
Mar 10, 2009 | Apple iPod touch
My wi-fi isnt working on my itouch!
well...ya'll need mental treatment coz it does work.....try comin' to ma crib...hhaa
Dec 12, 2008 | Apple iPod touch
HELP
All you should have to do is open Wi-Fi in system preferences. From there, touch the little blue circle next to the Wi-Fi network you're signed. Then, just hit "Renew Lease" at the bottom of the screen.
If that doesn't do it, completely turn your modem, Wi-Fi router and iTouch off. After 5 full minutes, turn on the modem, another 2 minutes later, turn on the Wi-Fi router, yet another minute at least, turn on your iTouch.
If that still doesn't work or you have any questions, feel free to call me.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 04, 2008 | Apple iPod touch
No wi fi for itouch
Usually, all iPods have a WiFi chip imbedded in the device so you have to pay nothing except for your currently active Wireless internet connection. Try checking your modem and making sure it's working for starters. If it is, then go on the iPod and go to settings, then internet connections. Select a valid internet connection and it should automatically connect, given a good signal strength.
If this helped/didn't help, let me know.
Sep 25, 2008 | Apple iPod touch
Connections problems
I had that problem in the beginning with my iTouch.
Have you checked your IP address?
Try opening settings, then open Wi-Fi, then touch the blue circle with the arrow in it that's next to your Wi-Fi router's name.
Once you're looking at a screen with your network's name at the top and your iTouch's IP address in the middle, scroll to the bottom of the page and touch "Renew Lease", then confirm by doing it again on the popup.
Now, scroll back to the top of the page and wait a moment. You should see the IP address go blank and then a new number should appear.
Hopefully you're online, check by opening App Store or Safari.
If not...
Turn off your iTouch competely (hold the lock/power button until the "slide to power off" slider pops up, then slide it).
Next, turn off your Wi-Fi router and modem.
Wait 5 full minutes.
Turn on your modem, wait 2 full minutes.
Turn on your Wi-Fi router, wait 2 full minutes.
Turn on your iTouch.
If all that doesn't work, call Apple Care... 1.800.692.7753
If you have any questions, please feel free to call me.
Mar 17, 2008 | Apple iPhone Smartphone
Apple iPod touch Logo
255 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
