My Sharper Image 5 Time Zone Atomic Clock has no number/digital display, even after I changed batteries, and resetting the clock. Could it be some problem with the LED display? What's the problem, and how to fix it? Thank you. Bich Tran
  • 1 more comment
  • btran40 Mar 10, 2009
    There is no display.
    Do I need to repost for more advice?
    I took the batteries out for 10 minutes, put them back, still no display.
    I put the reset button, still no display.
    There is also a back up batteries (3 volt). Do I need to replace that too?
    Thank you.
    Bich
  • btran40 Mar 11, 2009
    I opened the back and check the wiring, it seemed to be OK.
    The clock maker has the name of Sharper Image which has been closed down, filing bankruptcy. Any suggestion is appreciated.
  • 19,396 Answers
If the display is blank, test the LCD ribbon cable, if cable is fine , then probably the main controller board is defective.
Replacements for Sharper Image may be difficult to find, this unit will normally be considered beyond repair.
Posted on Mar 11, 2009
  • 6,784 Answers
Ok, the clock you have here is experiencing circuit board failure. the main transfer module has failed due to reaching its life span. these products from sharper have only a 3 to 4 year life span unfortunately. i bought an Ionic breeze from this company and it lasted only a year until the board failed. considering the fact that the company filed for bankruptcy, there i no way to send it in for this repair and i would just cut my loss and replace with a more durable atomic clock with better components.
    Sergeant:
    Champion:
  • 435 Answers
Hi, If it doesnt show even after changing w/ fresh batteries, the unit is defective. It cannot be fixed.
You may want to open and check if any wirings are cut.
Good Luck.
  • 2,794 Answers
It is tough to get fixed since Sharper Image is out of business due to bankruptcy.
Posted on Mar 10, 2009
  • 2,984 Answers
What is the model number?
    Master:
  • 763 Answers
I think sir your problem is on the remote control or the menu from the tv. try by looking thru the menu and find the display settings or you refer its manual for more information. it must be configured by mistake. i dont think that it cause the led display or hardware problem, its just a settings from the tv itself
thank you for using fixya
CHARCOIS
    Scholar:
  • 93 Answers
Even after you reset, and changed the battery, it is most likely a problem that cannot be fixed, unless your willing to open up the clock and replace the LED display, and thats only if the LED Display is replaceable. Or maybe the connections to the LED display are only loose? Either send it back if you have a warranty/receipt, or you have to open it up and check it out for yourself..
    Brigadier General:
  • 5,158 Answers
Take the batteries out and remove any power source for about ten minutes and see if that works
  • Roberta Smith
    Roberta Smith Mar 10, 2009
    when you removed the batteries... did you also remove the 3 volt battery at the same time.... if you don't it won't reset the unit
  • 10,515 Answers
Yup, its display error. tell me exactly what you can see so that i would be able to help you?
Are you able to see faint display or no reply?
Thanks for using Fixya.
How do I change the time zone on the Sharper Image Big Digit Atomic Clock Model SN001?
To access TurboTax, you need to have a valid username and password for the system. Now, different people use different versions of the device. Turbotax Support Number Some users opt for the online version or browser based version, while some users opt for the simple desktop version.
Oct 22, 2016 | Sharper Image Audio Players & Recorders
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
Time setting
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 19, 2010 | Sharper Image Wireless Caller ID with...
How to change time zone on the atomic clock
In my two clocks, it's part of the setup. You adjust it for GMT -x where x is -5 for Eastern, -6 for Central, etc. Mine also has an offset for DST.
Carl
Jan 09, 2010 | Sharper Image SI585 Clock Radio
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Sharper Image Weatherproof Atomic Clock Model OQ007
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Done.
Nov 03, 2008 | Audio Players & Recorders
I have a87900 model skyscan,can;t get it reset after replacing batteries
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Dec 17, 2007 | SkyScan 86742 Digital Atomic Wall Clock
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
