Question about Neptune Washing Machines
What is the size load of my neptune washer
How many cu ft in the neptune washer? Model #MAH4000AWQ
tzweeb
  • 318 Answers
SOURCE: trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Posted on Jan 31, 2009
  • 79 Answers
SOURCE: maytag neptune washer model #MAH4000AWQ
The famous Q6 and R11 failure can cause this issue. Have you replaced the faulty door latch wax motor yet? See www.neptunehelpsong.com for a video that explains what happens.
The Q3 triac (same part as the Q6 triac) will need to be changed on the board or the control board will have to be replaced along with the door latch wax motor if yours has the brownish color actuator pin. The new design has a black actuator pin.
Posted on May 23, 2009
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
  • 10865 Answers
SOURCE: What cu. ft. size is my Whirlpool top loading
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Posted on Jul 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
Where can I find the capacity load of my washer or how big is my washer?
acording to dealtime.com the Maytag Neptune FAV6800AW Top load washer has a volume capacity of 3.5 cu/ ft; or (Depth x Hight x Width) 29.25 in x 37 in x 27.25 in.
Mar 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
What is the size of this model? how many cu. ft?
This category includes standard-size top- and front-loading clothes ... Frigidaire. GLWS1649A. 449 $45. T. 85. 1.57. Frigidaire. GLWS1749A. 543 $54. F. 75. 1.26. GE. WCXH208A.
3.2 cu.ft
Oct 21, 2010 | Frigidaire GLWS1649A Top Load Washer
IHAVE MAYTAG NEPTUNE WASHER MODEL # MAH4000AWQ.I WANT TO KNOW WHAT IS THE SIZE IN CUBIC FEET?
If my calculations are right, this washing machine is approximately 3.00 cubic feet. You may want to double check it for yourself, though. I used http://www.ehow.com/how_6358141_calculate-cubic-feet-washer.html (updated 5/7/2010) to help in the calculation. My machine was approx 15"/1.25' deep and 21"/1.75' high. Hope this helps.
Aug 18, 2010 | Washing Machines
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The water won't stop therefore its pill out of machine. Have to manually turn the machine off, shut off water. Is there a sensor, leveler that may be defective? The machine model is MAH4000AWQ. Your help...
Check water level switch sensor. a small tube will be connected to this switch from the washer drum. This tube carries water inside the sensor assembley and senses!
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer model #MAH4000AWQ
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Neptune Washing Machines Experts
gbob59
Eric Taylor
Vernon Taylor
Are you a Neptune Washing Machine Expert? Answer questions, earn points and help others
