Question about Plumbing
Oil type required
I need to know what type/grade of oil I require in the hydraulics on my chamberlain champion 9G tractor?
  • 1 more comment
  • darryl_ott Mar 10, 2009
    Not sure exactly mid 50's I would say. Tractor has twin ram Front end loader and 3 point linkage.
  • Greg Bernett
    Greg Bernett May 11, 2010
    What is the year of the 9G?
  • Anonymous Mar 30, 2014
    gearbox casket for 9G cHAMBERLAIN TRACTOR AND other caskets as well
  • 2,984 Answers
Okay...heading to bed...will post to you tomorrow!
Posted on Mar 11, 2009
  • Greg Bernett
    Greg Bernett Mar 11, 2009
    Try a John Deere High Guard or equivalent.
What type of oil do you use in a david brown 880 selectomatic?
hydraulic oil suitable for the tractor
contact a service dealer for the exact type and viscosity
May 26, 2016 | Cars & Trucks
What type of fluids oil Etc are used in a 1987 JD 210C?
Fuel Capacity 23 gal 87 L
Hydraulic System Fluid Capacity 16 gal 60 L
Oil System Fluid Capacity 2.2 gal 8.5 L
Cooling System Fluid Capacity 4.2 gal 16 L
Transmission Fluid Capacity 1.8 gal 7 L
Feb 22, 2016 | Garden
Capacity oil for each turning brake and what grade for 977h traxcavator?
this is a car/truck site.. but I will try to answer this..most use gear oil on the track drive.. but the drives themselves are a hydraulic fluid ..there should be a reservoir that has capacities on it.. you may need to do an excavator website which this is not..and get your answers there..
Dec 30, 2013 | Cars & Trucks
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Dec 10, 2012 | Garden
What type of oil should I use for my Toro Timecutter 17-42Z?
Hello, If you have a Kohler Courage engine, you need to use 10w30. It has hydraulic lifters and requires the use of only this grade of oil.
Hope this helps.
Jul 26, 2011 | Garden
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
How do I replace the oil in the diff of a husqvarna lawn mower. the machine has done 350 hours of work. What type and grade of oil is used
If it is a hydrostatic drive unit, it is factory sealed and no maintenance is necessary or possible.
If it is a stick shift unit, it is packed with grease and does not require any maintenance.
The only exception to the above is that if you have a leak you need to take it to an authorized repair center where they have all the specialty tools required to repair them
Sep 17, 2009 | Husqvarna Garden
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 | Garden
Plumbing Logo
171 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
