Question about HP Pavilion DV9720US Notebook
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before . It is about 1 yr old I've changed power settings and nothing happens .i've tried changing default monitors and nothing changes. I've made sure I've updated the bios. I have also tried the fn+f7 and f8 key and nothing happens. I try to run in with and without the power cord and nothing . before it would dim on battery power. now its as bright as if I was on battery power. could I have a bad inverter ? I dont want to bring it back to the repair shop and get charged for something I could have done .. I have updated drives I've done a HP health check and it say everything works fine and latest drivers installed. the brightness is constant and I'd like to be able to adjust if for different situations .. can you help
    Scholar:
  • 180 Answers
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Posted on Aug 08, 2009
I have alenovo t420 laptop that brightens and dims every second or so . tried diablind the automactic brighten button under intel but this didn't work . am at a lost and need help .
Is it problem accours in another monitor that pluged to your notebook? If no, the possibility is inverter failure. Try to replace the inverter to your service centre
Sep 05, 2014 | Lenovo ThinkPad T420 Notebook
I got samsung laptop R580, the screen broke because of falling so i ordered online, and replaced it with new one myself, it was working fine for two weeks but after two weeks the screen went very dim! I...
The inverter could be faulty. The inverter supplies high voltage to the CCFL lamp that provides the back light. The inverter is located at the bottom of the LCD screen between the hinges.
Sep 09, 2012 | Computers & Internet
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
Dim screen
Its going to be either the lcd or the inverter more then likely. Go ahead and unhook the lcd cable from the motherboard and the back of the LCD. Reseat the cable into the LCD and the motherboard. If its still dim then the best thing to do is to replace the LCD cause it comes with the inverter.
Apr 28, 2010 | Dell Latitude D800 Notebook
Hp dv4000 screen turned pink now black
If its not the backlight inverter or cable. It will be the LCD screen itself. It seems the shop you took it to isn't really up on laptop repair, as this is a common issue I see often. Get on Ebay and find a screen for your model and replace it. I asure you this will fix your problem.
May 19, 2009 | HP Pavilion dv4000 Notebook
Hp 9720us note book has black screen. if I connect another montior it works fine, everything runs fine. Hp says it might be something to do with wireless.? This is my third laptop with problems in 15months...
This problem is the Display...everything is good.
Please don't forget to rate me "FIXYA"...thank you!
Mar 06, 2009 | HP Pavilion dv9000z Notebook
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion DV9720US Notebook Logo
672 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
