I took out the back panel (a dark gray piece labelled "HP") on my HP C4180 all-in-one printer, and now I can't see how to get it back in. No matter what I do, it doesn't seem to fit. I'm afraid of forcing it. What do I do?
  • dhenna1 Mar 10, 2009
    Thank you. The video was essential, and it did the trick!
    As I said in accepting this solution, the video made all the difference.  Pictures are worth a myriad of words when it comes to fixiing technical problems.  Thanks again.
  • 13,433 Answers
The user manual should have instructions on how to place ti back. Unless its not the backpanel? just a moment.
Posted on Mar 10, 2009
    President:
  • 1,314 Answers
Look on hp.com for a manual for your printer; it should be precise.
  • 1 more comment
  • Kevin Shafer
    Kevin Shafer Mar 10, 2009
    In fact, here is a video that even shows the piece being removed. Put it back in in the opposite way it shows at the beginning of the video.
  • Kevin Shafer
    And, actually after watching the video, it even shows a closeup of how that piece goes back on :c)
  • Kevin Shafer
    Thanks for the rating and you're welcome :c) Thanks for using fixya.
My HP C4180 when powered up shows on the display screen the following: 83c00020 and does nothing else. The only way that I can power it off is to unplug the printer from the wall outlet.
press cancell (red x)button adn power button at same time then release.you will see enter special key combo on screen. then press blue button once then green button once then gray button once. it willshow some support url... then press blue button 2 times you will see reset menu.press ok on it. then press blue button 2 times agaiun you will see semifull reset. press ok.then pritner will turn off.turnm it back on it will get resolved.
Dec 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
I took a plate off the bottom of my HP 6210 to clean up as much ink that had spilled as possible. I now have a 3 pieces to put back. The gray plate, a black "L" shaped piece and a retangular white sponge...
The white rectangle goes under the cleaning station, which is the black plastic box on the right as you look from the front of the printer. It also helps for ink overflow.
Nov 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to reset my cartage at HP c4180??...IDK how to do it...pls help
press and hold POWER and Cancel Button
wait for a Message in screen
Press the Green, blue and gray button in sequence
it will give u an Option of Reset menu... and u cn reset the printer
Nov 02, 2009 | HP PhotoSmart C4180 All-in-One Color...
HP C4180 prints fine, will not scan to imac, get error message, does not recognize computer
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
HP photosmart C4180 all in one. cannot get it out of print queue
jst try deleting the printer icon from the printers window under the control panel,if it shows deleting,unplug the printer,restart your computer and then try deleting it again.it should go off,then plug the printer back in,and follow the on screen instructions.
if it is still not working then delete it from the device manager>usb composite device .it should delete the drivers,then plug the printer back in after restarting and follow the instructions.
Feb 19, 2009 | HP PhotoSmart C4180 All-in-One Color...
Printer labels do not line up with document as typed in Word using the Avery set label size. I type labels for Christmas cards. Previous years have had no trouble at all on other printers but now top of...
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Nov 21, 2008 | Office Equipment & Supplies
C4180 HP All in one printer
Check the following steps:
Open the control panel and Right click on the printer icon and select printing preferences.
Select Layout option and check for front to back option and click OK.
Regards,
Sagarjd
Aug 27, 2008 | HP Photosmart C4180 All-In-One InkJet...
H P Photosmart C4180 All-in-One Printer - Scanner - Copier--no go.
Go to the printer SETUP button. Select the TOOLS option, then pressed OK. First, select the CLEAN PRINT CARTRIDGES option. Wait until it finishes. Second, select the ALIGN PRINT CARTRIDGES, under same TOOLS menu.Wait until this finishes and let me know if this cleared the wrong message.
Jul 30, 2008 | Office Equipment & Supplies
14 people viewed this question
jasbo
jasbo
