Question about Philips DVP5990 DVD Player
DVd audio sounds slow
I have a Philips DVP5990 DVD player. I was watching a dvd and my three year old daughter was messing with the remote control, and next thing I know the audio sounds like it's in slow motion. The picture looks the same but voices sound slower and deeper. I have no clue what she did. please help!
  • 814 Answers
Check you owners manual for the audio settings. Check these pages and note that the underline setting are the factory settings.Pages 37-41.These are the setting most likely changed. You can always reset the player to factory settings. This will most likely restore everything to normal. This procedure can be found on page 47. The reset function is call default. This is a factory reset function.The function is found in the settings menu under the preferences.If you do not have a copy of the owners manual handy, you can use this link and find a pdf copy on the philips website. If you still cannot get the player working correctly, you can call the Phillips customer support at this telephone number 1-888-744-5477. Give them the model number of your dvd player and the problem you are having with the sound slowing down. They will be able to help you solve this problem. I hope this information help you solve your problem.
Posted on Jun 02, 2009
I bought an all region philips dvd player but does not play english dvds
JOB DONE .....
Dec 07, 2010 | Philips DVP5990 DVD Player
Colour distortion
Try a new video cable assembly..
Sounds like the other colors arent getting thru from the DVD player
Apr 20, 2010 | Philips DVP5990 DVD Player
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
What is the code i can use on a philips dvp5990 dvd player to make it free from any region ,i just got this dvd player at best buy the sales person said that this dvd has a code i can set on the remot...
hello Doramichell1
Here is a link for you.
Along the top of the screen click the option CODES then select Philips. I could not see you model number there. What I would suggest you do is try a code that is close to your model number.
Hope this helps you out. Please leave a thumbs up if this helps you out.
Little Dish Fitter
Oct 07, 2009 | Philips DVP5990 DVD Player
I installed a parental control code on my phillips dvp5990 dvd player and forgot the do you reset it?
This information was found on the Phillips USA website in the customer support section for you model dvd player. In the owners manual on page (47). I hope this information helps you with your problem. Select this to set the password for Parental control and Disc
Lock. The default password is ‘136900’.
To change the password:
1) Press OK twice to access the change password menu.
Old Password
New Password
Confirm PWD
2) Use the numeric keypad 0-9 on the remote control to
enter your existing six-digit password at { Old Password }.
Note: When doing this for the first time or if you forget your
existing password, enter ‘136900’.
3) Enter the new six-digit password at { New Password }.
4) Enter the new six-digit password again at { Confirm PWD }.
5) Press OK to confirm and exit
May 07, 2009 | Philips DVP5990 DVD Player
I was told that this model DVP5990 read french dvd
Power on the dvd player and with no dvd or cd in the dvd player, Press the setup key on the remote control. This will put you in the set-up menu. Use the up and down arrows to find the preference section. Highlight it and press ok and then press these number keys in this order. The region sub-menu will appear. On the region sub-menu use the up and down arrows to select the (0) region, Press ok. This will make the dvd player region free. Now press the setup button again to exit the set-up menu.I hope this information help you with your problem.
Feb 20, 2009 | Philips DVP5990 DVD Player
PHILIPS DVP5990 -region free problem
In order to have access to the Preference screen, you need to have the CD tray closed with NO DVD/CD in it. If you have a CD or DVD loaded in the tray, the Preference menu is disabled.
Unlock procedure..
press Setup
select the Preference Tab
Press 1,3,8,9,3,1
Press up/down key to select "0"
and hit menu to exit.
Jan 02, 2009 | Philips DVP5990 DVD Player
How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Nov 02, 2008 | Philips DVP5990 DVD Player
Philips DVP5990 DVD Player Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
