Question about Pioneer GM-5300T Car Audio Amplifier
What does the system control wire get hooked up tooo??????
  • 55 Answers
It's just a remote wire it goes from your amp to the car stereo. usually on the wire harness for your cd player the color is BLUE but it should be labeled.
Posted on Mar 10, 2009
I have a new one Remote control for Samsung Dvd HT-X20
me tooo and touch screen with voice activation
Aug 20, 2014 | Audio Players & Recorders
Steering wheel controls
JVC radio doesn't work directly with car's steering wheel control. You need an adapter. Metraonlie.com offers pretty reliable ones.
Aug 25, 2013 | JVC KD-G230 CD Player
Wiring to fuel system which is hook up to the computer
The computer is hooked into the fuel pump relay, and controls pump operation by activating the relay. The computer internally grounds the relay coil side, allowing power to pass through the relay to the pump.
Dec 14, 2011 | 2000 Chevrolet Cavalier
I paid $20 last night to talk to someone. He told me how to hook up the Lux DMH110 but when i hooked it up this morning the heater came on when i put it on COOL and the fan just come on when i put it on...
If you have this type of system your thermostat will not work;
  • Multi-Stage Heat Pumps
  • 3 Wire Hydronic Systems
  • Line Voltage Systems (120/240 VAC)
  • This thermostat is only for this type of HVAC systems;
  • Most 24V Heating and A/C Systems
  • 1 Stage Heat/1 Stage Cool: Gas, Oil, Electric, or Single Stage Heat Pump Systems
  • 2 Wire Heat Only Hydronic Systems (Hot Water Baseboard & Radiator)
  • Millivolt Systems (Wall Heaters / Furnaces & Gas Fireplaces)
    1. Never connect a low voltage thermostat to line voltage.
    Two wires control a heat only system.
    1. Connect one wire to W and the other to RH.
    Two wires control a cool only system.
    1. Connect one wire to RC and the other to Y.
    Three wires for forced air heat only system, where the previous thermostat
    did not have a clock or timer.
    1. The previous RH or RC wire is the 24-volt transformer wire. Connect it to RH. Leave jumper connecting RH to RC. Connect the forced air heat system to W, and the fan wire to G.
    Three wires for a heat only, forced
    water system that did NOT have a
    clock or timer.
    1. This system employ 3 wire zone valves. Currently no Lux controls are compatible with this system.
    Three wires control a heat only, forced water system that DID have a clock or timer.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W.
    Four wires control a heat only system,
    and two of the wires operate clock or timer. The other two wires operate the heater.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W. The jumper connecting RH to RC may remain or be removed.
    Two wires control heating AND cooling.
    1. Currently no Lux controls are compatible with this system.
    Three wires control heating and cooling. One wire operates heat, one operates cooling and the third provides 24 VAC.
    1. Connect the 24-volt power wire to RH. Install a jumper connecting RH to RC. This jumper is usually pre-wired. connect the heat wire to W, and the cooling wire to Y.
    Three wires control a cooling only system. One wire operates the compressor, one operates the fan and the third provides
    24 VAC.
    1. Connect the 24-volt power wire to RC. Connect the cooling wire to Y and the fan wire to G.
    Four wires control a heating and cooling, electric, gas or oil, forced air system that
    is NOT a heat pump.
    1. Connect the 24 VAC transformer wire to RH or RC. Install a jumper connecting RH to RC This jumper is often prewired. Connect the heat wire to W, the cooling wire to Y. and the fan wire to G.
    Four wires control a Single Stage Heat Pump. They were labeled: G, Y, R or
    RH or RC, With either B or was used.
    1. Do not connect wires to both B and O. Connect the reversing valve wire to B or O, just as the previous thermostat. Install a jumper wire from RH to RC. Connect 24 VAC wire to RH too. Install a second jumper wire from W to Y. Connect compressor wire to Y and the fan wire to G.
    More than 4 wires are connected to the
    old thermostat
    Jun 27, 2010 | Heating & Cooling
    What does the red wire attach to for a k4221 photo control?
    The power wire coming into the control has a black, white and copper (ground) wire. Hook the balck wire to the control black, All the gound wires hook together, all the white wires hook together, then hook the red wire to the black of the light that you want to turn off and on.
    Nov 13, 2009 | Intermatic K4221C Photo Cell Control 120 V...
    My REMOTE CONTROL FOR TV HAS VERY WEEK RANGE CAN I MAKE IT POWERFULL
    Try replacing with new Cells ....
    and clean the IR LED of the remote ...
    clean the IR receiver of the TV tooo.
    basic range is 15feet it should work if it is working
    Sep 28, 2009 | Televison & Video
    Viper remote starter sets off alarm.
    Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
    Dec 12, 2007 | Viper (VGC421) Remote Control
    Pioneer DEH-225 Car Audio
    The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
    Oct 07, 2007 | Pioneer DEH-225 CD Changer
    Pioneer GM-5300T Car Audio Amplifier Logo
    182 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
