Question about Dell Dimension 4600 PC Desktop
Computer starts up in DOS
When I turn on my computer it starts up in DOS, when I hit enter it will go to my desk to. How do I get it to start up naturally?
  • Chinmay patil
    Chinmay patil May 11, 2010
    what it shows on screen before you hit enter?
  • Thomas F. Schneider May 11, 2010
    Have you looked at the boot priority in the BIOS setup screen?
    Habit-Forming:
  • 152 Answers
You need to edit your config.sys file a file that you don't need in WinXp You can download a boot disk(see link) from Dell that will have the tools you need to work on your hard disk. If you don't understand DOS you might want to get somone to help you. mysleuth
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=boot+disk&cat=all&x=0&y=0
Posted on Mar 10, 2009
  • 51 Answers
What operating system do you have installed? If you are using windows Then you need to repair your boot files. Start with boot.ini. you can open this using notepad editor. the info should read:[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Thats is you are using XP Home Edition operating system. If this doesn´t work then you need to run msconfig. Start menu select Run, then type msconfig.Startup selection should be normal check box. System.ini should have all check boxes checked,Same as win.ini, when you get to boot.ini tab, no boxes should be checked. I hope this helps. Start with the second method first ok.
Mscustomercare com lookbook
Disable and reenable your network card. Check your firewall setting in your operating system. Turn it off. Check your network card settings. Make sure it is set up for a dynamic IP assignment (no fixed IP numbers in the setup). Click start, then run. Type in CMD and hit enter. That should open a DOS window. (yes DOS is alive and well). Type ipconfig /all then hit enter. Look and see if you have an IP address. Compare what you see to the other computers in your house that are connecting. The first 3 sets of numbers should be the same. For example 192.168.1.5. The other computers will have a different number in the last set. For example 192.168.1.2. If you are getting all zeros or it starts with a different set of numbers your router isn't assigning you an IP. Check your router settings.or visit this link.....
http://compnetworking.about.com/od/internetaccessbestuses/tp/fixing-cant-connect-to-internet-problems.htm
Feb 13, 2014 | Computers & Internet
Tip
How to reset bios password on basically any pc
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
on Jul 24, 2010 | Computers & Internet
Tip
Basic BIOS password crack - works 9.9 times out of ten
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
on Jul 16, 2010 | Computers & Internet
How do I do a factory reset from safe mode with command prompt? windows xp
Restoring Windows XP operating system can be performed in DOS mode if XP's system restore tool cannot be accessed because of booting issues or when the XP recovery CDs are unavailable. There are two steps to this procedure: first, the XP system restore tool must be accessed using the DOS menu and second, the actual XP system restore is performed.
Start the computer and press the F8 key when the manufacturer's logo appears but before the Windows XP logo appears. Scroll through the menu options using the down arrow key. Select "Safe mode with a Command prompt" and hit the Enter key. Type in the administrator ID and password. Hit "Enter." Type in this code in the command prompt box to access the XP system restore tool: %systemroot%\system32\restore\rstrui.exe. Hit "Enter." The XP system restore tool will open. b> How to Restore Windows XP b> Click "Restore my Computer to an Earlier Time" when the XP system restore tool starts. Click "Next." Choose a restore point before your operating system began to malfunction. Click "Next" and "OK." Click "Next" to begin the XP restoration process. Do not turn off the computer or attempt to stop the system restore tool, as this may damage the hard drive. The system restore tool will automatically restart the computer when it has finished restoring the operating system. Hope this helps.
Dec 12, 2012 | Computers & Internet
Computer says its locked; change users, but my mouse is locked up too.Im using my desk top to contact you.
You can use the windows key to open the start menu, then use your arrow keys to hightight turn off your computer, hit the enter key, use your arrow keys to highlight restart and hit your enter key This will restart your computer and hopefully, unlock your mouse.
Let me know if this solution works for you. If all else fails, it is acceptable to push the power button until the computer turns off, then hit it again the turn the computer back on. This is not the normally acceptable procedure for shutting windows down, but in this case, it can be done without any negative repercussions.
Brian
Jan 02, 2011 | Computers & Internet
Black screen, no start buttton but documents pops up
upon starting the computer keep pressing the F8 key
It will bring up the repair screen
Choose a safe mode with the command prompt
hit enter wait for a new screen and hit enter again
The screen should be in the DOS mode showing C:/ Windows
type in chkdsk /r /f
answer yes (Y)
shut off and restart
Jul 11, 2010 | Microsoft Windows? Vista Home Basic...
Cannot log on to my computer. Does not accept log in name.
start the computer in safe mode by pressing F8 during boot up. You will notice there is now an admin account. Open the admin account and then click Start/Run In Run type cmd and hit enter. When dos opens type this " net user yourname * " without the quotes. Dos will ask for a new password, enter it and your done. Restart the computer and your new password is set. :)
Jul 01, 2010 | E-Machines T1742 PC Desktop
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
First try flushing your DNS file aka Hosts file. You do this through a cmd prompt. To open a cmd, go to start and type in cmd and hit enter. In Vista you just type in cmd in to the search bar in the start...
No, both FireFox and Internet Explorer use the same "cache".
So, "flushing" (in order to "empty") the cache will either fix the problem in both web-browsers, or will _NOT_ fix the problem in either web-browser.
Oct 18, 2009 | Computers & Internet
Getting grey screen with wrong machine
Create a bootable DOS disk and place it in the drive. Then restart the system. that should get you to a DOS prompt. At the DOS prompt you can tell it to change to the D: drive. You can tell if you have done this right because you will see a D: as part of the prompt. Insert recovery disk 1. If it does not start reading the disk type DIR at the D drive prompt. That will list all the files on the D: Drive. There should be one called autostart or install. Type in the name of the file including the extension. Hit enter.
A second approach is to hit F12 during start up and drop down to the second item and hit enter. That started the Toshiba recovery disk for me once when it would not read it automatically at start up.
Dec 14, 2008 | Toshiba Satellite A105 Notebook
Dell Dimension 4600 PC Desktop Logo
75 people viewed this question
Alun Cox
