Question about Garmin StreetPilot c550 GPS Receiver
I am unable to delete. Following instructions to no avail.
Also just did the bluetooth thing but I cannot find
phonebook in screen to add phone numbers and save.
  • 6,784 Answers
On the main page, touch the blue phone icon.to open the phone menu then, touch the phone book icon. it looks like a phone book in the top left hand corner of screen. you can add numbers here.
Posted on Mar 10, 2009
How do I pair my Motorola Droid Maxx with my Subaru car phone?
You'll want to go to Settings > Bluetooth on your Droid Maxx. Turn Bluetooth on and also make it visible. Ensure you keep the phone's screen active while the phone is visible. Then on your car you should initiate the steps found on Subaru BlueConnect for Bluetooth . The car should then initiate pairing. Watch the screen on the car as it might ask to pair with your phone and provide a PIN code. If it does, enter it on your phone to validate the connection. Watch for additional steps that might suggest syncing of your contacts/phonebook, call history, etc. If you have issues. Contact Subaru for assistance.
Mark
Motorola Support
Sep 13, 2014 | Motorola Mobility DROID Ultra XT1080 16GB...
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
New phone DECT1480. How do I delete the new cid numbers
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
Oct 18, 2017 | Uniden Lands Phones
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
SGH-u700 - Ford Sync - Bluetooth - downloading phonebook
contact your samsung mobile store and have them upgrade the sync for you to pair with the car.
May 30, 2009 | Samsung SGH-U700 Cellular Phone
I deleted a contact phone number by mistake on my blackberry.
Unless you "sync'ed" with your desktop you cannot un-delete. Chances are that you didn't sync with your desktop, otherwise, you probably already know that you can restore from the desktop application and therefore wouldn't post the question. Following are some alternatives that may help you partially.
What you can do as an alternative is find it in your call history and use the menu buttons to "Add to Phonebook" and recreate the contact. This assumes you know the person's name and other contact info, but just want the phone number back.
Likewise, you should be able to find an old email and "Add to Phonebook" that user's email.
I hope that helps.
Apr 17, 2009 | RIM BlackBerry Bold 9000 Smartphone
Garmin 265wt. How do you delete duplicate # fm phonebook?
I can help you with the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
Contact Transfer via Bluetooh to a 2005 Lexus
Problem seems to be witht the Car Bluetooth and Navigation system.
Feb 27, 2008 | Sony Ericsson Z310i Cellular Phone
Garmin StreetPilot c550 GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
