Question about Kenmore 63663 Microwave Oven
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
AFTER A FEW SECONDS OF OF TRYING TO OPERATE F9 APPEARS IN THE DISPLAY WINDOW. WHAT DOES F9 MEAN? HOW DO YOU REPAIR THIS PROBLEM.
  • 408 Answers
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Posted on Mar 10, 2009
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
MICROWAVE DOES NOT HEAT.
The F-9 error code indicates a defective control board, inverter or line voltage too high.
Repair or Replace them.
Thanks.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave will turn off a few seconds after start.-
It seems there is something wrong either with the builtin controls or the buttons. It needs to be examine by a professional.
Oct 31, 2017 | LG Over-the-Range Microwave
F-9 appears on microwave when I try to heat somethingIt
First of all, I would bet your model number is 721.64683300 not 731.64683300, right?
The F9 problem in this microwave is a bad magnetron or inverter.
From other users:
"F-9 on this microwave IS inverter related. My problem was the magnatron and checked out bad with the help of (the tech sheet). It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron."
"f9 Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
The first thing I would suggest is a hard reset. Unplug the unit for several minutes or so. Then plug it back in, set the clock and try again.
If it fails again and you or someone you know decide to look into it further, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find exploded views and order parts by entering your model number at the
Sears parts site.
The magnetron probably has an extended warranty beyond the normal one year parts and labor warranty.
So I would consult your owner's manual or contact Sears for details on the warranty.
To get your owner's manual, just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Dec 16, 2008 | Microwave Ovens
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Kenmore 64683 Microwave Oven
Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
Jul 04, 2008 | Kenmore 62622 Microwave Oven
Kenmore 63663 Microwave Oven Logo
444 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
