Question about Xerox Phaser 8400 Laser Printer
Error Code: 07,010.43:263647 The printer gives me the code and automatically powers down. Anyone know what this means, and how I can fix it?
    President:
  • Xerox Master
  • 1,314 Answers
From the service manual:
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox
being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the
process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive
module shaft are at home position.
6. Verify the headtilt gear will engage, see the home
positioning procedure on page. You can manually
engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails
replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper
drive system.
Since posting all these test would be impractical, let me know if you need the service manual and I can send it your way. Thanks and please take a moment to rate as fixya.
Posted on Mar 10, 2009
HELP ! My HP C309a photosmart 3in 1 printer
Hello and Welcome!
The error
Oxc19a0040 is mostly occurred in HP printers
To solve the error code
Oxc19a0040,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Thank you for using FixYa!
Jun 08, 2012 | HP Photosmart Premium C309A All-In-One...
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
Will not play cd's and gives error code
I am not sure it is much help but as far as I know the eprom is in the computer. The computer is directly below the CD player.
So duff computer?
Nov 12, 2009 | Nostalgia Electrics Classic Music Jukebox...
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Older Canon Copier PC-6re
Then Error code means that the fuser / fixing Lamp is blown or it could be the thirmal fuse is blown. It could also a bad thirmister, that may have caused the fuse to blow. One thing you can look at, will the fixing unit get warm or hot. Do you know any copier techs, as a friend. It is not a easy job to fix this problem. You have to fix it to clear it.... Good Luck
Mar 14, 2009 | Canon Office Equipment & Supplies
E803 Error Code
e 803 error .that is for dc controller or composite power board .if power board just change it.
Dec 16, 2008 | Canon imageRUNNER 210S Copier
Error code problem
Unplug printer. Press and hold power button for about 15 seconds. 5C00 is a hardware service code. Meaning there is an EEPROM error on the printer systemboard. Which may need to be replacing by a certified techinican.
Jun 23, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Xerox Phaser 8400 Laser Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
