Question about Dell E173FP 17" LCD Monitor
Bright light in centre screen of lcd pc monitor
    Master:
  • 505 Answers
They called burnt out mega pixles it cant be fix unless you replace the screen
Posted on Mar 10, 2009
Sunlight prevents me from seeing my monitor
If you mean the LCD display on the back of the camera you can adjust the brightness in the camera menu. Press the menu button, move to the yellow spanner with 2 dots top right, below this you'll see LCD brightness, highlight this and press set you'll then go to another screen showing a scale 1 to 7 use the left / right button to move the pointer closer to 7 to increase the screen brightness.
May 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
LCD back light is off or very dim
I changed monitors and it works??? What worked. Did the brightness appear? Is the monitor now functioning properly?
If not, monitors can have increase brightness by using the menu settings. The settings can be accessed by the buttons that are usually below the monitor screen on the front under panel. Adjust the brightness from there.
If that fails then change the monitor. That you are suggesting that the backlight is out, I am assuming that you have a flatpanel monitor and not a CRT. Either can be configured the same way using the menu buttons; however, the back light issues are different in the two types of monitor.
Good Luck
Sep 28, 2009 | Dell Dimension 2400 PC Desktop
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
Brightness settings pop up repeatedly
Try checking the connections, if it's not try reloading the software that came with the monitor.
Jun 07, 2009 | BenQ FP71G 17" LCD Monitor
Screen So Bright I Can Barely See Anything...
Unfortunately the problem is the monitor has gone bad, more specifically and likely is the backlight which is used to light up the monitor. You could fix it by replacing the LCD, but you can get monitors cheaper than a replacement LCD so it wouldn't be very cost effective to do so.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
Camera monitor very light
The LCD Monitor Brightness has a range of -5 to +5.
Rotate the mode dial to Setup. Turn on your camera.
Go into the Setup Menu, then Custom, then select LCD Brightness. Make adjustments as needed.
Let me know if this fixes the LCD monitor. Thank you, Binary Bob
Nov 10, 2008 | Vivitar ViviCam 5386 Digital Camera
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
Alun Cox
