Question about HP Compaq Presario SR1110NX PC Desktop
Pc will not power up. Green light on power switch blinking like a slow stobe light. I tried un plugging it, did not work. I tried swicthing it to 240v, then back to 120v did not work. I tried an alternate power source did not work. I tried holding the start button down plugged in, and not plugged for 10 seconds did not work.
  • Chinmay patil
    Chinmay patil May 11, 2010
    do you hear any beep sounds ?
    Champion:
  • HP Expert
  • 237 Answers
The power supply is shot. Best suggestion is to replace it. You need to make sure it is replaced with the same model power supply. Check online for a replacement unit.
Posted on Mar 10, 2009
My mum has a evesham laptop she run it pluged in mains before she plugs into computer the charger is just green and when she plugs it into laptop it starts to flash and laptop will not swicth on can u help
Sometimes this is caused by a bad battery, you could try taking the battery out and run it off the mains, however, with this make of laptop, like Gateway and Hi Grades, the issue probably lies in a burned out or faulty power board. The flashing light on the charger indicates that power is being, for want ofa better expression, "rejected" by the laptop... current has nowhere to go, so it is not flowing and the blinking light is indicating this.
As to repairs.. suggest it needs stripping down, oddly enough,the problem might just be a simple short caused by a screw working loose and shorting out a component
Jan 03, 2011 | Computers & Internet
I unplug my pc and put it back after a few hrs then plug it back but there was only a blinking green light it does not turn on or off i tried everything like plug off and plug it on still the same i tried...
check the back of the power supply and make sure the voltage selector is set properly. try to switch it back and forth to the correct voltage. Swap the power cord with the monitor. Switch it on again. If the blinking green still comes up, press and hold the power button for about 5 seconds and see how it goes. If this does not work, disconnect all removable items and cables inside the system including power connection and connect them all and test the system again. Hope this helps
Nov 13, 2010 | HP Compaq Presario SR1230NX (PJ518AA) PC...
I disconnected my compaq Rresario S5500 to clean it, but when I put the power cord back in, it didn't switch on. There is flashing green light at the rear. What could be the problem? I was using it few...
when you were cleaning it you might have damaged it or knocked something loose, inside the pc. take the side cover back off and reseat all the cards and the memory also the processor carefull not to crack the mobo..then un plug waite for the grn. light to stop blinking and plug back in..
Nov 23, 2009 | Computers & Internet
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
GREEN LIGHT KEEPS BLINKING PRINTER DON'T PRINT
hi rudy, thank you for using fixya.
when you said a green light was blinking was it the power light or another green light on the printer?
i strongly suggest that you refer to these links to have it fixed if it is a blinking power light.
For instructions on how to clean the ink cartridges: http://www.fixyourownprinter.com/forums/printer/26642.
For a diagnostic procedure: http://www.annoyances.org/exec/forum/winxp/1073811565
For instructions on how to un-install and re-install the print drivers and other Lexmark software problems: http://www.techspot.com/vb/archive/index/t-10556.html
otherwise, we are looking forward to your reply.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Won't turn on
Open your cabinet,
Make sure that your computer is swithched off completely.
Remove your RAM,
Rub it with an eraser (on the connections),
Plug it back,
Swicth on.
Please rate.
Dec 15, 2007 | HP Pavilion A700N (PJ516AA) PC Desktop
HP Compaq Presario SR1110NX PC Desktop Logo
303 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
