Question about Magic Chef CGR1425 Gas Kitchen Range
Magic Chef CGR1425ADW oven - electronics problem
Display says either "S A6" or "5 A6" (can't tell)... no electronic oven controls (bake, broil, clock, timer) will work. Stove igniters / burners work fine.
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: i have a magic chef stove .model numberCGR3742CDQ
You will have to replace the ERC. Electronic Range Control.
Posted on Jun 15, 2009
redkcir
  • 36 Answers
SOURCE: Magic Chef gas range oven not working after cleaning
You controller is your likely culprit. There is a relay on it that controls the oven. When it first wouldn't go off, the contacts in the relay stuck together. When you unplugged it you may have had to pull it out from the wall, which may have broke the connection. It works by way of a small electromagnetic coil that brings the contacts in and out. If that coil breaks it will look like it is on, but won't have any power to the oven coils. These controllers are easy to replace, but expensive. $75 to $300 depending on what you need for your unit.
Posted on Jan 04, 2010
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
Jan 04, 2010 | Kitchen Ranges
I have a Magic Chef range. It has the touch type
The touch pad for bake could be nonfunctional or the bake relay could have failed. Do you hear a click like the relay has activated? If so the ignitr could be the prblem. Careful investigation is required.
Eric
Dec 19, 2009 | Kitchen Ranges
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Oven goes on off on off on off and it does not get
This is a common symptom caused by a problem with the ERC (Electronic Range Control / Clock). If you can send us the ERC, we can rebuild it for you.
Bruce
Aug 09, 2009 | Magic Chef Kitchen Ranges
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Magic Chef CGR1425 Gas Kitchen Range Logo
285 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
