Question about Samsung HLN617W 61" Rear Projection HDTV
Is there a way to do a master reset or reset to defaults for a Samsung DLP Hln617W? The colors are messed up after another family member decided to try to tune it and I'd like to find a factory default reset method. Thanks in advance.
    President:
  • Samsung Master
  • 1,779 Answers
Usually in your menu under picture controls at the bottom, should be a reset option. Most all sets do, especially Samsung. Let me know if you can't find it?
Posted on Mar 10, 2009
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp tv makes loud noise when turned on. Previously it was turning itself off.
Bad Color Wheel, Located Right Behind Lamp when you remove Lamp you will see the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
PN# BP96-00250A Price $82.66
Oct 03, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp hln617w aging pattern problem
I am actually having the same problem. I just reciently installed a new bulb and messing around in the service menus, and ended up with the same problem. I found that if if in the same menu the aging pattern was in, I think it was the last menu, and click on the EW RESET, let the TV reset and that should fix your problem.
Dec 10, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
426 people viewed this question
Jerry Greenberg
Jerry Greenberg
