Question about Hitachi NR83A2S Framing Nailer, Full Head, Plastic Strip Collation
Nails ride over each other and don't shoot straight
When you put in 2 clips of nails the front of the 2nd clip sometimes rides over the back of the 1st and then they don't shoot strait.
  • Dean
    Dean May 11, 2010
    Does the nail magazine have a slot that the nail heads are supposed to sit in?
  • 24 Answers
Check and make sure your using the right nails. Are they held together with plastic? This should be a 21* full round head nail with plastic collation
Posted on Apr 14, 2009
How do i take off part number AM123734
The deck height adjustment knob; there is an E clip that goes through the knob and that locks it on to the shaft. These are spring steel and have the nickname of "ahh crud" clips (when you push it out (it slides in place) it will probably shoot out the side opposite of the way you push it: "ahh crud" can be substituted). Once you slide the clip out (save it because you reuse it) the knob will slide up off the shaft. Putting in on is just: put the knob on, slide the E clip back in place.
Jan 25, 2015 | John Deere Garden
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
I inherited a Bostitch N805B uses 28 degree .113 and came with clipped head nails. Will it shoot full round head nails?
I could only find a Bostitch N80SB full round head nailer in their lineup so I hope that's what you have. No it will not fire full round had nails because they are stacked at a lower angle to accomidate for the full head and material used to hold the strips together. Senco does make a full round head nail that fits their clipped head nailers but it does not list the Bostitch nailers as one they will fit into so I don't know if they will work in your gun. The Senco part number for their three inch, full round head nails for clipped head guns is K527APBK.
Jan 31, 2012 | Tools & Hardware - Others
Don't know how to load the nails in the gun
There are two ways dependent upon the gun model. Pull the charging handle back and insert the nail clip with the forward facing, leading edge POINT in first. Some guns allow you to put the nail clip(RACK) in the gun then pull back on the charging handle. BOOM your ready to shoot.
May 28, 2011 | Tools & Hardware - Others
Paslode 2nd fix firing pin seems to ride over the top of nail hence not shooting it to right depth
Ok the only thing that keeps it from riding over the top of the nail is your quick release on the front of the tool. I bet when you go to latch the front that it is not very tight. you need to replace the whole door. This should take care of you problem. # 900759 front plate assembly
Apr 21, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
How do you remove front or rear wheel on craftman riding mower.model #917.270921
You should find little clips holding them in place. Take a screwdriver and find where the hoop (clip) has a notch in it and put pressure against should pop out (wear eye safety gear). Once clip is off....tire will pull off
May 27, 2010 | Craftsman Garden
2 nails shoot at the same time
It could be just from using poorly clipped or collated nails. I have noticed that with some cheaper nails, the clipped heads are not all lined up properly. If a nail has rotated slightly during the collation proccess, the unclipped portion of the nail head protrudes over the previous nail in the clip. This causes the heads of two nails to be struck at once. Another problem I've encountered is collation wire that doesn't shear off with each nail. An ever lengthening strand of wire protrudes into the nail chamber and eventually the driver snags this wire as it drives a nail. This jerks the clip forward forcefully forcing more than one nail into the chamber or causing the next nails in line to rotate slightly, thus exposing the unclipped portion of the nail heads to the driver.
Mar 13, 2010 | Tools & Hardware - Others
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Hitachi NR83A2S Framing Nailer, Full Head, Plastic Strip Collation  Logo
126 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
