Question about HP Pavilion ze4200 Notebook
This is daniel again i have the hp pavilion 4200 that will not reconize the hard drive was working fine the day before i took it out. even when i try to run the operating system cd that came with the computer it goes through the process like it is goin to load and then says ( an unexpected error (32768) occured at line 5152 in d:\xpsp1\base\boot\setup\setup.c. also when i try to load the recovery cd pack it will start up fine then once it starts trying to copy it says error 49 write fault. the blue busy light lites up on the hard drive and u can hear it spinning but the computer will not reconize it. HELP what do i need to do also when i go into the bios and try to run the hard drive self test it says diagonistics not supported \Thanks Daniel
  • kbdesign
    kbdesign May 11, 2010
    Does the hard drive show up in the BIOS?
  • 538 Answers
Defective HDD
Posted on Mar 19, 2009
Can i replace the the hp pavilion DV4000 SERIES 80GB (4200 RPM) HARD DRIVE with any 7200 rpm notebook hdd?
You should be able to replace it, but you will need an adapter lead from laptop hdd to motherboard as the laptop hdd will be smaller and you may need a kit to fix hdd into 3.5" bay. Both are readily available.
Feb 13, 2011 | HP PAVILION DV4000 SERIES 80GB (4200 RPM)...
I want to clean my hp dv 4000 hard drive in order to sell......How do I do that.......i still have the software/hardware to restore.
Have a look on ebay under computers then hard drive erase. There you can get discs for £1.79. I have used a version of these myself and they work very well. Don't know whether you are planning to reinstall OS or not. Hope this helps.
Jan 22, 2011 | HP PAVILION DV4000 SERIES 80GB (4200 RPM)...
My Hp Pavilion dv2810 does turn on but nothing appears on the display. Also, hard drive light does not go on and does not seem to "move". Usually when computers are turned on, you will notice hard-drive is...
I am also facing the same problem with my HP Pavilion DV2810US laptop. It was working fine till other day when while using Facebook, my screen scrambled and then shut it down using power button. After that when I tried to turn it on again, it doesnt have any display. All the indicators though are on but the hard-drive indicator is not on. Please advise if anyone has faced same issue.
Jul 10, 2010 | HP Pavilion Dv2810us Notebook PC
HP Pavilion DV6812 is not recovering or restoring!!
If you mean this errors
STOP 0x0000001a (0x00041284, 0xca9a2000, 0x000077e0, 0xc0c00000) MEMORY_MANAGEMENT
STOP 0x0000004e (0x00000007, 0x00007abf, 0x0000f17e, 0x00000000) PFN_LIST_CORRUPT
STOP 0x0000000a (0x00000028, 0x00000002, 0x00000000, 0x8012d2d6) IRQL_NOT_LESS_OR_EQUAL
STOP 0x00000050 (0xc2332b94, 0x00000000, 0x00000000, 0x00000000) PAGE_FAULT_IN_NONPAGED_AREA
Its ram problem,so first if you can access the bios check if your ram are been recognized and load default bios settings.If are OK in bios remove RAM and reinstall again.If the problem still exists try again testing your Ram with the Microsoft program or with that.
If the programs founds an error you RAM are damaged and replace them.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Regards
Aug 03, 2009 | HP Pavilion dv2610us Notebook
"No IDE device" in BIOS drive selftest in HP Pavilion zd8000
any moisture on the motherboard
will destroy components if plugged in
even if yoru laptop is cold in your car , is ok
but when you bring it inside and plug in fast
condensation can burn out the tiny components, motherboard is bad
Jul 18, 2009 | HP PAVILION ZD8000 SEREIS 100GB (4200...
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says...
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Mar 08, 2009 | HP Pavilion ze4200 Notebook
Hard drive
hi, enter into BIOS setup and check the drive configuration for whether the drive is detected, and the size of the drive it shows. If it is correct, your hard drive may be ok. other wise the guy you contacted may be correct.
Jun 27, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion ze4200 Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
