Question about Sterling RF30 Natural Gas Garage Heater
Sterling garage heater wont always light.
My heater will try to kick on 3 or 4 times. You can hear it light for about 3 secs and then shut off. It does this 3 or 4 times then doesnt try again. Then i have to reset it. It seems if it cools down it will fire right away. Say in the morning when i turn the heat up it wont have a problem, but after it runs a while and has to start up again it will go through the process of not starting. Sometimes during the 3 try cycle it will kick on, but its starting to get worse.
  • salvatore115 Apr 06, 2009
    i have a stering rf 75 and and it tries to fire 2 or 3 times and then stops sounds line the igniter has an eratic sparks, how can i fix this problem
  • Sterling Expert
  • 252 Answers
The flame sensor is dirty - have the unit serviced. Modern furnaces require regular maintenance!
Posted on Mar 12, 2009
Can a sterling garage heater be vented out a side wall of a garage
Yes, should have a chart in the installation book that shows distances to windows.
Sep 23, 2014 | Sterling RF30 Natural Gas Garage Heater
Bought a sterling 75 c garage heater burner lights but then 24 v transformer burns out
I didn't find that model but did see a pretty standard wiring schematic for Sterling garage heaters in one installation manual. I'm sure they didn't change much. I did notice they use a 50va transformer, not 40 which is likely what is getting used now. Don't think that would fix it, just an idea. Put a 5 amp fuse inline on the red side of the secondary side of the transformer. This will protect it. I'm willing to bet the ignitor section on the low voltage common is wired wrong. Remove the tstat wires, buy a resettable fuse and install it first. Then get the fan running first. If there is a g terminal jump red to green. This is fan only, start simple, hope this helps
Jun 18, 2017 | Sterling RF75 Natural Gas Heater (75,000...
I have a Sterling garage furnace,pilot is on ,but main burner will not light.
Be sure you turned the Control knob from Pilot to ON. Without doing that the heater will not turn. If that's not the problem, the Thermopile may need replacing. Also, check the volume of gas at the heater. It should be a minimum of 5 to 7 water column inches. If it has a wall thermostat, be sure the wires are correctly installed at the heater and the wall thermostat and the it's turned up higher than the ambient air temperature in the garage. If this is an older installation, be sure the exhaust vent piping is not blocked.
Feb 09, 2011 | Sterling RF75 Natural Gas Heater (75,000...
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
Green light flashes when i try to start my TFO 75 garage furnace
Looked at Sterling garage heaters in general. 3 blinks read pressure switch. You should have code chart on furnace door. Pressure switch symptoms are blocked vent or moisture in small hoses connected to pressure switch or bad pressure switch. If small hoses have sags take off one end and dump or both ends and blow through.
Jan 23, 2011 | Sterling RF75 Propane Gas Garage Heater
Burner comes on but fan wont work, then burner is so hot it shuts off, then the same starts all over again. bill
I would first replace start capacitor on fan motor. If that doesn't work I would replace motor. Hope this helps. Thanks
Nov 18, 2010 | Sterling RF30 Natural Gas Garage Heater
Noisy heater...flashing green LED light...Is there a problem?
with sterling , the flash could mean all is ok or the count of the flash could mean an issue,,,,,
without knowing your exact model i will send you here
http://www.sterlinghvac.com/html/literaturelibrary.asp
look for your model or design
and read the maint. section
this is what i use for all my sterling service calls
Oct 22, 2009 | Sterling RF30 Natural Gas Garage Heater
Sterling rf30 unit heater fan motro cycles on but unit wont fire.
Hi check out the pressure switch jump this out seeif itn lights check flame senser blow heatout with air line hope this helps
Mar 28, 2009 | Sterling RF30 Natural Gas Garage Heater
Sterling RF30 Natural Gas Garage Heater Logo
1,034 people viewed this question
Top Sterling Heating & Cooling Experts
Paul Carew
bobalix
deton8 von Splosion
Are you a Sterling Heating and Cooling Expert? Answer questions, earn points and help others
