Question about Toshiba Satellite A105-S4164 Notebook
Display Settings - Single Monitor Option Has Disappeared
I have my mum's computer here - a Toshiba Satellite laptop. Her start menu/taskbar has disappeared and reappeared as a split screen. It seems to be a separate screen or window and can only be manipulated horizontally. I have checked display settings and there is no choice available but multiple monitors. I have no idea what happened and nothing I have tried has worked. Help ... please! Thank you. Nancy
  • whiteiris Mar 10, 2009
    Oops, sorry ... Windows XP Home
Need to know your OS
Posted on Mar 10, 2009
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba X205-SLi4 went through one of those updates where it has to do 1 of 3, 2of 3 etc configurations. Then it rebooted and now we have no monitor. You can tell it is on, but nothing comes upwhen the...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used?3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status").7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 23, 2010 | Toshiba Satellite® X205-SLI4 PC Notebook
Toshiba L10 display will not work.have pressedfn+f1 and fn+f5 but to no avail.
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?). 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 22, 2010 | Toshiba Satellite L10 Notebook
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
Could not get the display on projector with toshiba laptop A70
There should be a display settings section on the graphics settings for the card in the laptop. Sometinmes these are from Intel, Nvidia, ATI, etc.. In this section you should see display1, display 2. Right click on the one opposite your LCD display and you should get an 'activate' option or use this monitor. If you are not getting these options please post your Video Adapter information.
Jun 05, 2009 | Toshiba Satellite A70 Notebook
Taskbar and start menu disappear
Move the mouse to the bottom of the screen to make the taskbar reappear. If you want this to display at all times, right-click on any blank area of the taskbar and select Properties. Clear the checkbox next to Auto-hide the taskbar.
May 31, 2009 | Dell Inspiron 1525 Laptop
My screen is bigger than the monitor for my toshiba satellite laptop.
Hi.
What is happening is the settings that you have set on your laptop are too high for the monitor to recognize.
You will need to reduce the resolution settings in you display properties which can be found by going to start-settings-control panel- display- and in the display area choose settings.
Some video cards will let you adjust each item. Some you have to use the same resolution on both screens.
Shout if you need furthur input !
Fran
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
I cannot re install my start up bar the file display
In XP, go to Start > Control Panel > "Taskbar and Start Menu" and open it and you should be able to show and lock your Task bar aka "menu bar" from the Taskbar/Start menue options you'll see there.
Good luck.
Feb 24, 2008 | Toshiba Satellite A135 Notebook
Toshiba A100 laptop dark moniter
Try with external monitor and see if it work.If it work just go to the display properties settings advanced and change settings there
Nov 01, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105-S4164 Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
