Question about Kenmore 42822 Front Load Washer
Removing control panel on a kenmore elite he3 front load washer
Could anyone tell me how to remove the control panel to check for loose connections? Washer will run for a few seconds then lights will flicker and then washer will beep and timer will flash can then push start will work for a few seconds and then repeats with the same. Saw code f11 once only. Any info would be greatly appreciated.
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
I cant get my kenmore elite he3 washer to start keep getting dl F error
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
May 04, 2010 | Kenmore Elite 45986 Front Load Washer
How do i open the front panel of my Kenmore Elite HE3 washer to replace the interface board?
To access the front panel, or to take it off persey, you would have to remove the top of the unit, this isnt hard as it is fasted by a few screws in the back and you slide the panel back and then you will have access to the front panel mounting screws and remove those to remove the front panel.
DrakeTech
Feb 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 washer problem. F11 flashes at the spin cycle
If this is showing up as an intermitten problem, chances are that it is just a loose connection.
The F11 code indicates a Serial Communication Error. In english this means that there is a problem communicating with your CCU (the main computer for your washer) and the MCU (the motor control unit).
First remove the top panel (3 torx screws along the top of the back of the washer. If you don't have a torx 15 bit a 1/4 inch nut driver will do the tick)
The CCU is the large white box with all the wires connected to it. It will be on the right hand side of the washer. Check all the connections here first. If everything seems in order then check the MCU next.
To check the MCU, remove the kick panel on the bottom of the front of the washer. Again this is 3 torx head screws holding this on.
The MCU is located on the left hand side right against the side panel. It's white in colour. The connectors will be underneath a little flap (just push it up, there is nothing that is clipped to it). Check these connections.
If you have not found a loose connection your best bet is to call for service. At this point it'll be either the MCU that's failed or the CCU. Without doing certain tests to it it's impossible to know which one.
Good luck! Please let me know if this was helpful!
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
Dec 31, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore 42822 Front Load Washer Logo
500 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
