Question about Garmin StreetPilot C330 GPS Receiver
Display image has shifted, difficult to use
Turn on the unit and the image has shifted up and over making it hard to access all the features on the touch screen. How to get it reset?
StreetPilot c330 is 4 years old.
  • dualplanker Mar 13, 2009
    This did nothing. The solution that worked was:
    To recalibrate the touch screen:
    Turn the unit off.
    With the unit off, touch and hold the Power button for 30 - 40 seconds.
    Follow the instructions on the screen.
  • 6,784 Answers
Ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Posted on Mar 10, 2009
  • Michael Masters
    Michael Masters Mar 13, 2009
    good deal, you figured it out. awesome:)
Cannot reseat imaging unit in xerox phaser 6130 printer
You can find answers to your Xerox questions at www.xerox.com/support
Solution : Replace the Imaging Unit CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap.
Do not drop or shake the Imaging Unit after it has been removed from the printer as Toner spills can occur.
Do not expose the Imaging Unit to any light source for more than five minutes. Prolonged exposure to light may damage the unit. Cover the Imaging Unit with a light shield (such as a sheet of paper). Do not touch the shiny blue Transfer Belt.
  1. Power OFF the printer using the power switch located on the left side of the printer, toward the back. Press the power switch to the OFF (O) position.
  2. Press the button on the top right side of the printer to open the Front Cover.
  3. Locate the Imaging Unit, and then turn the four twist-locks to the left to unlock the unit.
  4. Grasp the Imaging Unit by its peach-colored pull-tabs on the top edge. Pull the unit forward and up, and then out of the printer.
  5. Place the used Imaging Unit in a bag and make sure the bag is properly sealed before discarding or recycling.
  6. Remove the new Imaging Unit from the shipping container and the sealed package.
    CAUTION: Do not remove the orange protective cover from the front of the unit until it has been installed in the printer. This will protect the Transfer Belt from being touched during installation.
  7. Place the Imaging Unit on a flat surface. Hold the unit firmly with one hand and with the other hand grasp the end tab of one sealing tape and pull the tape straight out, horizontally. Repeat for the remaining tapes; there are eight tapes in total. Make sure none of the tapes have broken. Discard of the tapes as normal office waste.
    NOTE: If any tape breaks off with the remainder inside the Imaging Unit, stop the installation and contact Support.
  8. Grasp the new Imaging Unit by its peach-colored pull-tabs on the top edge and install the unit in the printer. Make sure to insert the unit into the guides in the printer, and then push the unit all the way back into the printer.
  9. Turn the four twist-locks to the right, to lock the unit.
  10. Pull the orange protective cover out and then down from the top, center of the Imaging Unit.
  11. Close the Front Cover.
  12. Power ON (') the printer. A 'Ready to Print' message will be displayed on the Display Screen.
Nov 28, 2013 | Xerox Phaser 6200N Laser Printer
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
I have a aspire 5515 acer with Vista Basic and i want to install Xp Pro. When i try to install Xp pro it starts and the comes back that it is quiting the installion because it will damage something. How do...
There's no single way to install Windows XP. As there is no CD / DVD drive, you have two main choices:
1. Purchase an external CD / DVD drive. Plug it into a USB port on the Aspire, and then access the BIOS, Make sure the CD drive is first, and insert your Windows XP disc. You should now be able to install it normally.
2. Use a bootable Flash drive. This method will be far more difficult, and requires a moderate amount of experience with computers. First you will need to install QEMU on another computer. Create a hard drive the same size or smaller than the one in the Acer. Install Windows XP to it using QEMU. Copy the hard drive image onto a USB Flash drive. Now install some version of Linux on it, such as Puppy Linux or Damn Small Linux. Howtos are available in the Related Links section below. Boot from the Flash drive, and access a command line. Find your hard drive in the /dev folder (probably sda or hda). Now issue the following command
dd if=image.img of=/dev/hda
This will make an exact copy of the hard drive image to the hard drive in the Acer. Waituntil the command is completely done. Now turn off the computer and unplug the flash drive. When you power it back on, it should boot into Windows.
Jun 13, 2009 | Computers & Internet
Can't shift
You probably burnt the clutch up.
A good indicator is hard to get into 1st with out grinding as well as reverse, and over all poor ability to shift in any gear.
air in the slave cylinder is more then likely not your problem.
Its pretty hard to do.
May 23, 2009 | 2006 Ford Mustang
Printing not clear (its so Blur)
Perform these operations:
  • Test->Diag->Clear->NVRAM
  • Test->Diag->Clear->CalData
  • Then re-calibrate the printer.
Procedures:
  1. Turn ON the Tech Access feature (hold ENTER and LINE FEED keys depressed approx. 5 seconds - until printer "beeps")
  2. Turn ON the Fault Override feature (hold ENTER and FORM FEED keys depressed approx. 5 seconds - until printer "beeps")
  3. Press the MENU key then UP Arrow to Offline - Test Menu
  4. Press ENTER then UP Arrow to Test Menu - Diag
  5. Press ENTER then UP Arrow to Diag - Calibrations
  6. Press ENTER then UP Arrow to Calibrations - Print Engine Cal
  7. Press ENTER and follow the instructions on the display
  8. Turn OFF the Fault Override feature by holding the ENTER and FORM FEED keys depressed until the printer "beeps"
  9. Turn OFF the Tech Access feature by holding the ENTER and LINE FEED keys depressed until the printer "beeps"
Mar 18, 2009 | Tally T6218 Matrix Printer
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Canon EOS 300D LCD monitor problem
turn off the camera.
remove the battery.
wait 10 seconds
replace the battery making sure the power is off.
then turn the power on.
that might reset the board.
otherwise, you might have arced the power if the unit was on when the battery was removed. if so, you have a service issue you can't fix on your own. refer to qualified servicer.
good luck
mark
Nov 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
Acer PD113 DLP Projector
If you can work an the micro level of troubleshooting, have access to the the necessary instrumentation and tools, have the proper surface mount soldering station, test jigs, and also be able to have the access to the factory diagnostics software, and required replacement parts, then I would say you can troubleshoot and service this module. The factory service centers replaces this module. They don't spend the time and cost to service it at the component level. I have serviced some types of projection screen systems. They are very complex, and are normally serviced at the modular level. After replacement of some types of modules, some factory adjustments are required to match the new module, or parts. In the end you will have to send the unit out for factory service.
Jan 24, 2006 | Acer PD113 Multimedia Projector
Garmin StreetPilot C330 GPS Receiver Logo
131 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
