Question about Alesis iO 26 Sound Card
Frequent random glitches/drop outs in sound
This unit worked fine on my Mac, but when I use bootcamp to run windows, I am getting these little playback glitches sporadically and frequently. itunes plays back fine, but sound forge, logic, acid and even realplayer all experience weird little pauses in sound very frequently. The lights on the firewire will often flash for a second when this happens. I have the most recent drivers and the unit is only a few months old, anyone know of a fix?
thanks
Got the exact same issue!! ,, could that be an OS problem ??!
Posted on Feb 12, 2010
  • deliui Oct 04, 2010
    Hi there
    I got an IO26 too.
    Here`s an idea.
    I got the same issue after I moved the computer and had to unwire/rewire everything.
    I have a 2 channels FireWire adapter and after I plugged into the other channel it seemed to have stopped dropping out.
How do i get Dazzle TVstick 71e to work on Mac?
You don't, this TV stick was only made to work in windows.
You could run Bootcamp, Wine Bottler, WinOnX.. these will allow you to run Windows, but the TV card is hardware and may still not work.
Hope this helps..
Aug 23, 2014 | Computers & Internet
Intel core2duo no sound windows xp
I take it the laptop is dual boot and the sound works ok when used under Mac OSX.
If this is the case, then the laptop probably needs the audio drivers for windows. These can be downloaded from the Apple website (Bootcamp Drivers) or by using the 'Bootcamp' utility on the Mac side.
Oct 15, 2013 | Intel Computers & Internet
Mac hangs on shutdown during automatic restart - black screen, flashing power light.
Apple icon top left corner, click menu drop down, click FORCE SHUTDOWN click each item intern to close.
Apr 13, 2012 | Computers & Internet
If parallel or Bootcamp for intel Macs is installed on my MAC, can Age of Empires: Rise of Rome be played with out a CD in CDROM drive?
Yes, just download the file for Age of Empires: Rise of Rome as if you were on a PC, then install it through Bootcamp. However It may be cheaper just to buy the game because Bootcamp is not exactly cheap. If you want to do this for multiple games then Bootcamp would be the way to go.
Mar 14, 2011 | Microsoft Age of Empires: The Rise of Rome...
Used bootcamp and tryed to install windows and got disc error ,now wont go back to normal statas. how do i fix?
Insert the Mac OS disk in the drive and reboot while holding down the C key. This will launch your computer in Mac OS and then you can access Disk Utility from the startup window.
Rebuild/ repair as needed, then I suggest removing any partition that you may have set up and re partition your drive for the windows stuff. Give yourself ample room on the harddrive for your windows software and files.
Be sure to print out a copy of the instructions for bootcamp before you launch... also be sure to allow it to automatically set up your mac for windows. Do this:
1.set up a partition according to the directions for bootcamp
2. install windows as per bootcamp instructions
3. after it's launched in windows, insert the Mac OS disk and it will launch all the setup for your mac hardware to run windows... modem, wifi, all that mojive that you usually need to spend hours in PC land ..mac will set it up for you.. Also download a copy of Bonjour from the Apple site. this will set up your printers for use in windows very easily and quickly..
The main thing is follow the directions and let the computer do all the setup...
May 21, 2010 | Apple iMac (MA876LL) 20 in (MA876LLA) Mac...
How to install on mac
You cannot install this software on a Mac. It is only compatible with a Windows PC. However this Apple program will do all it will do and more. http://www.apple.com/finalcutstudio/finalcutpro/
Dec 15, 2009 | Sony Screenblast Movie Studio 3.0 for PC
Windows
Hi benny, im Nick from germany.
In order to install Windows on a Mac computer you'll need these things:
- Apple Macintosh with Intel Processor
- Windows XP Install CD with Service Pack 2 or higher
- You can also use Windows Vista CD
To get started, you just need to start the mac and do a search for "Bootcamp" in Spotlight (the search in MacOSX, top right corner).
Note: This only works on Mac OSX Leopard, for Tiger its a little more tricky.
Once you started Bootcamp, it will guide you through the process of partitioning your harddrive and installing windows.
If it doesnt work, its probably the fault of the windows install cd. I had to use 3 different versions to get it to work.
If you need additional help, feel free to ask =)
Jan 21, 2009 | Computers & Internet
Mac compatible computer cool school???
If you have a modern (Intel) Mac running Leopard, you can use BootCamp, which is on your computer, to install Windows XP or Vista on your computer in a separate partition and run the software there. Other options that are a little simpler include using Darwine, a program that can run *some* Windows applications on Mac. The easiest solution would be to return the product to the store, because these companies are unlikely to ever produce a Mac client for your product.
Dec 30, 2008 | Fisher Price Video Game Consoles & Games
Parrallels
I would suggest you look in to Apple's Bootcamp. Although you do not want to run in a dual-boot configuration, Bootcamp allows you to create a CD with all of the Mac's windows drivers.
I appologize but I am not totally sure if 1) the Bootcamp drivers contain a camera driver and 2) if the camera works at all within Parallels.
Worth a shot though.
Nov 29, 2007 | Apple MacBook Pro Laptop Computer with...
Alesis iO 26 Sound Card Logo
306 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
