Question about Refrigerators
Installed a new door gasket on my freezer but it does not seal as well as the old one. What did I do wrong ? Freezer is a frigidaire model mfu14f3gw
  • 856 Answers
Try taking it off again and putting it in hot water for about 5 minutes. This will soften it up. Now reinstall it and close the door. This will help form it to it's new home. New gaskets are always a problem for a few days.
Try this and hope it works out for you.
Posted on Mar 10, 2009
Icicles in the freezer and frost inside door of freezer. Normal for brand new refrigerator?
It sounds like the seal isn't closing completely. If there is any gap around the seal air is probably entering and the moisture is freezing. This sometimes happens when the doors are reversed. Try heating the gasket with a hair dryer if there are gaps in the gasket.
Sep 24, 2014 | Refrigerators
I can't close the door;How ca I change the rubberband on the door?
the rubber band on the door ( the door seal or gasket ) loosen the screws around door and pull off old gasket . install new and tighten / kepping door flat and square . ( very important .. cke for proper seal . . you may have to rack the door for good seal and retighten screws. ,, mm
Aug 11, 2010 | Frigidaire FRT21P5A Top Freezer...
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    I need to change the door seal on a 1990 ge fridge and top freezer, looking for tips on how to remove and replace seal. i have the new seal.
    place new seal in warm water for 15 min. start at one corner, remove appr 4 srcews in each direction pull old gasket down. now start to install new. continue to remove old and install new. make sure to remove weight from door. after your done place a film of vasoline on mating surface.i sometimes will roll a small amount of paper towel to insert where gasket is not wanting to pull up . push door firmly shut for a few days.
    Jan 19, 2010 | GE GTS18HCM Top Freezer Refrigerator
    The gasket of Frigidaire FRT8B5EW4 partly detached from door. How can I fix it?
    no easy fix / you need to order new gaskets . / make sure thery warm when installing . ck the seal after replacing . with a $5 .00 bill . or a $10.00 will work .. **** .. hope this hepled .
    Jan 06, 2010 | Frigidaire FRT17G4B Top Freezer...
    My self-defrost freezer (18.5 cu ft, 11 year old, refrig on bottom/freezer on top) has begun to frost up primarily around the door (inside). I have insured that nothing is close to the door to avoid the...
    Test the gasket by closing the door on a dollar bill. If you can pull the dollar out easily then the gasket is not sealing. If the gasket is OK then the auto defrost function may be not operating. High humidity and opening the door frequently can also cause some frost build-up.
    Aug 12, 2009 | Frigidaire 18 Cu. Ft. Bisque Top Freezer...
    My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
    High humidly could cause condensation or the magnetic seal could be bad.
    A couple of things to try;
    The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
    Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
    Dripping from the Ice maker water supply?
    Jul 15, 2009 | Frigidaire Refrigerators
    INTERIOR FRIG LIGHT
    replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
    Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
    Refrigerators Logo
    118 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Richard Roth
    Richard Roth
