Question about HP DeskJet 3740 InkJet Printer
My HP Deskjet 3740 had a paper jam. I removed all the paper. Turned the printer and computer on and off several times but the printer still thinks it has a paper jam. I can't get the printer to work at all.
  • 53 Answers
You have to check if there is still a piece of paper jammed in the printers rollers/gears. It is inside when u take the lid off. After that you can try to recalibrate your printer from the software which came along with the printer. Try these and give more clarification.
Posted on Mar 10, 2009
Hp 3740 says it has a paper jam...no paper in it. rear door has been checked and replaceed.
You might have a small piece of torn paper caught up inside. Try feeding and manually ejecting a new piece of paper through it You might have to take a flashlight and look inside for a bit of paper.
Dec 21, 2016 | HP DeskJet 3740 InkJet Printer
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
HP Deskjet D4100 1) The arrow pointing down near the power switch is flashing. Printer will not print. 2) The printer goes "offline" Paper is not jammed, have unplugged/plugged. rebooted numerous...
First, here is a link for the troubleshooting your printer: https://support.hp.com/us-en/product/hp-deskjet-d4100-printer-series/501868
I always go the the manufacturer website to download drivers. I also just had a similar problem on our printer at church. Two people looked and looked after pulling a jammed paper out of the printer. I looked a few times, opened the 2 back doors, the front door, removed the paper trays and looked, opened the side door, and looked again. Each time the printer said jam. I got a flashlight and looked everywhere again, nothing. Still said jam. I looked one more time in above where the paper trays go, and under a piece of plastic just barely visible at just the right angle was a tiny scrap of paper, not much bigger than a quarter. I managed to get it out and all works fine. Possibly you may have something like this going on?
Dec 22, 2017 | HP Deskjet D4100 series
My hp 3740 Printer's power button is blinking and doesn"t print since yesterday.
Blinking power light can mean a jam, out of paper, open cover, or bad usb cable.
Open the covers and look for torn paper and nothng blocking the paper sensor. Check and make sure your USB cable from PC to printer is connected.
Dec 31, 2010 | HP DeskJet 3740 InkJet Printer
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
Top light with (x) blinking
Fixed this problem this morning by unplugging the printer from the computer, plugging it back in and changing out both cartridges (color and black) and replacing with new cartridges.
Don't know which helped. I had been unplugging the computer from the power source but not the printer from the computer.
My four year old printer is still cranking - good open forum you provide here. Thank you !
In that spirit, I decided to contribute my update ..... Judy
Sep 12, 2008 | HP DeskJet 5550 InkJet Printer
I control panel under pinter it says paper yam
in this case , what iLL do is to "REBOOT" , UNISTALL EVERYTHING that has to do with the HP printer , I mean everything ,after deleting all driver of printer , go to START , click SEARCH , and write " hp deskjet 3740" click search , if something shows , delete it , then install the drivers again ,
this is in case you havent found the solution for this particular issue , hope this helps , AJ
May 13, 2008 | HP DeskJet 3740 InkJet Printer
HP DeskJet 3740 InkJet Printer Logo
598 people viewed this question
Ben Johnson
