Question about Hitachi 53UWX10B 53" Rear Projection Television
Need two speaker
My speakers are blown. I need new one for this unit.
Can any one help me.
Thanks
    Sergeant:
  • 319 Answers
How many are there? i have some hitachi speakers from my old big screen. 6 total?
Posted on Mar 19, 2009
Porsche Carrera bass speakers inoperative
Either your speakers are blown, you have a loose connection somewhere, or your amp is bad. First thing to check is the amp. If all looks good then you probably need new speakers. Be sure to check all fuses, and, the super simple stuff- like verify the bass setting on the head unit isn't turned all the way down to 0
Aug 22, 2013 | Porsche Cars & Trucks
Need driver for Logitech Z-340 speaker system.
Sounds like the Subwoofer is blown. Unless you are handy with this stuff, you're outta luck unless you can find someone with the expertise to replace the blown speaker inside. This is not an easy job. If you are up for it you can follow the previously described method for opening it & removing the blown speaker. A suitable replacement can be found at http://www.rpelectronics.com/d03-0004-4-speaker-paper-cone-4-ohm.html Note that it will need to be mounted differently than the original which is mounted on the rear of the panel.
The replacement must be mounted on the front. It will need some sort of gasket (foam tape or something) between it & the panel. No soldering is required as push on connectors are used. Connect it up after installation and reassemble the unit.
Be aware that there is a possibility that the sub's amp is blown, in which case replacing the speaker is of no use. It would be good if you had some sort of speaker to connect to the terminals once you get the unit open and check that the amp is putting out before ordering a replacement speaker. Good luck!
Nov 17, 2012 | Logitech Z-340 Computer Speakers
Front speaker problems
Order speakers from the manufacturer, or uninstall the blown one and bring it to your local wal-mart or auto store and they can help you find the proper speaker. If you intend to purchase them online, you will have to take dimensions of the speaker or find the dimensions from the vehicle's parts catalogue.
Dec 03, 2009 | 2005 Chevrolet Aveo
Blown fuse in Subwoofer unit, what amperage to
usually it is 0.5 amps. if it still blows, you might have a shorted board.
Nov 25, 2009 | Logitech X-530 5.1 Channel Speaker System...
12 blown velly
If you have an HGS unit, the only source for a replacement speaker is Velodyne.
You will need to contact velodyne for the price.
Oct 28, 2009 | Velodyne HGS-12 Subwoofer
Subwoofer is crackling - maybe blown? Was
Crackling is usually a sign of a blown speaker or a misaligned coil.
Both can be very difficult to fix themselves.
However you may be able to buy a new speaker .
You would have to dismantle the sub and remove the broken one first.
A goo hi-fi shop or even musical instrument shop may be able to help you with that.
You would need to know the impedance of the blown unit along with its frequency range. That information would usually be in your user manual.
Its not a difficult job but if it is a powered sub then be aware of electrical hazards and ensure it is disconnected from all sources before attempting any work.
Oct 08, 2009 | Boston Acoustics MicroMedia Computer...
DAV-IS10 Speaker Blown
OK, Subwoofer model number is SA-WSIS10and you need middle speaker mounted on top under following part number..
1-826-658-11 LOUDSPEAKER (12 cm) (MIDDLE)
Available in Part Store.
Mar 23, 2009 | Sony DAV-IS10 System
My front speakers and tweeters are blown
I work at a Chrysler Jeep dealer and sell parts, and I'm sorry to tell you but this is a little problem we have run into many times with these vehicles. The factory speakers are **** and of course we have no wiring diagrams showing how to install aftermarket speakers without replacing the head unit with an aftermarket one. I just had to do this with my Mitsubishi Galant when I bought some Focal component speakers for my doors. I went with the Alpine radio and it seems very nice and I think it will do great for your speakers also. Hope this helped.
Jan 13, 2009 | 2002 Jeep Liberty
A whispering in my right speaker
If a fuse is blown the units will not work at all. This is the unit itself. If you have everything connected properly, the the amplifier package inside the speaker/sub is damaged. Return or replace. Nothing that you can really fix unless you are electronics savvy.
Oct 11, 2008 | Logitech Z-2300 Computer Speakers
Wiring new speakers
hello melgiblett, as adding additional speakers to you current factory speakers will cause and abundance of power drain, you head unit is only designed to handle 4 speakers.. the only option would be to either splice your front or rear speakers to the new 6x9's, however you will notice a significant drop in audio volume and quality as your head unit would not be powerful enough to run all 6. with the assistance of an amplifier, you may be able to acheive all 6 speakers
May 31, 2008 | Car Audio & Video
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
