Question about AT&T Sony Ericsson W580i Cell Phone - White
Always in usb connection mode
I wash my phone in my pants and since then it starts up in usb connection mode now matter what. If you plug it in to the computer then it works fine but wont charge.
  • 360 Answers
Try placing the phone in a sealed ziplock bag of uncooked rice, without the battery, to try to draw out any remaining moisture in the phone. Try using again after a day or so.
Posted on Mar 10, 2009
The say to dry clean only. Can you wash them?
When a Fabric Tag indicates exactly How the garment is to be cleaned, then that is the correct way. To try and Wash a garment that should be dry cleaned-is to have the Fabric tear apart at the seams, and Rip into different frayed sections-with spotted dyed parts showing.Always follow the directions on your Fabric Tags!
Feb 27, 2014 | Express Womens Leathertrim Tweed Wide...
Are pants tighter when you first buy them?
Yes new pants are usually tighter and they will stretch out when you wear them. I usually find that they return to their normal size once they've been washed but over time they do tend to stretch.
Jan 14, 2013 | Clothing
Ok i bought a iphone from a pawn shop an do not know the itunes account password an cant get any updates help
Turn on the phone and Reset it back to default settings. You will then have to register with Itunes for your own account
- or -
Try and do some info gathering on the phone itself for leftover information and use the forgot password option.
Feb 18, 2012 | iPhone Apps
What mode should camera be in to upload pictures does it matter if you connect usb cable to ccamera or computer first
It should be in playback mode. It doesn't matter if you plug in camera first or computer first but it does matter that you have to first install the proper drivers for your camera on your computer. The proper drivers is on the CD that came with your camera. Install that first before connecting your camera to your computer. Personally, I don't like to connect camera to computer unless I'm doing an update to the firmware. I would suggest buying a USB memory card reader if your computer/laptop doesn't have one already. Then I upload my pictures by removing the memory card from the camera and plug into the USB card reader. Best of luck.
Feb 28, 2011 | Canon PowerShot SD1000 Digital Camera
How to connect nokia 6300 in pc via USB
heya !
Before you plug your phone to your PC install the Nokia PC suite from here OR ovi from here. It 's usefull to save the contacts datas and other things to your PC, or to synchronise PC and Phone.
1 . You need to have a USB/mini-USB Cable to do that.
you can find it here for exemple.
2 . you have to plug the Mini-USB into your phone here
3 . the other part of the USB Cable go into your PC.
When you plug the phone to your PC you will have to choose the mode of conectivity you need to transfer datas :
-Nokia mode (it use the software Nokia PC suite OR ovi)
-UsB connect (it use windows explorer as an external disk)
-and an other mode that i haven't use yet.
*Voila :)
Bbye.
Denyzor
Jul 28, 2010 | Nokia 6300 Cell Phone
When i connect my LG cookie to the comp., cant open usb storage..
try changing the usb connection mode in ur cell first. Change it to "Always Ask" n then nw connect it. On connection, U'll b asked to choose any one of d mode 4m diff modes. So, select nw "Mass Storage"......
May 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Menory card
How to connect your memory card with PC. Here's what u do:
1.In your mobile, go to Menu, then Settings, then Phone settings.
2.Scroll down to Pc connections.
3.Select "Mass storage" option.
Next time you connect your mobile to the PC via the USB, open Samsung Studio. Samsung Studio will automatically detect your memory card and then you can start transferring files.
Another simpler method is when you connect the mobile via the USB, go to My Computer. Click on Removable Disk. Then it's just a matter of dragging and dropping files from there on.
Note: When connecting your mobile, make sure it is in Idle Mode (i mean in the main screen mode)
Hope this helps.
Thanks for using Fixya...
Aug 28, 2009 | Samsung Modem Configuration Software...
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
My LG Ku990 Viewty phone wont connect properly to my pc
just change the connection too mass storage on usb connections (phone settings) and then scroll to the bottom and click view files :)always works for me
xx
Nov 12, 2008 | LG KU990 Viewty
Can't get out of USB mode
You most likely need to change a setting called USB Connect under main settings 1.
Page 67 of http://pdf.crse.com/manuals/3208400121.pdf
Default is auto
I suspect it is set to mass storage and is causing your hassle
Mar 04, 2017 | Sony Cyber-shot DSC-W200 Digital Camera
AT&T Sony Ericsson W580i Cell Phone - White Logo
35 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
