Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Requires several times just to get started and then runs fine for about 5-minutes and cuts then cuts out on its own. Then have to wait for about 10-15 minutes to start again but still requires several times to get started.
    Problem Solver:
  • 7 Answers
The most likely problem is the ignition module. It is probably going out. when a bad ignition module gets hot from use, it stops working, which kills the lawn mower since there is no spark. Once it cools off it sometimes works. This can be a some what costly part, $60 - $80. You might want to take it to a lawnmower repair shop and have them check it out, since there are other issues that could be the cause to your problem. If you have a spark tester, you could test the ignition module to see if you get spark, both before you start the mower, and after it quits on you.
Posted on Mar 10, 2009
ive had this problem with my 03 grand am gt. all i have to do is turn key to not try to start it. if your security light is blinking sit and wait for it to stop. usually it will be about 1 minutes. then shut your car off wait 5 seconds and start your car. i have never had to do this more then 1 time during that incident.but some say they have had to do it a couple a times. the problem is in the passlock. the only way i figured it out was youtube. there are other ways to fix this but it requires cutting wires and splicing them and you wont ever have this again. ive had this happen to me at the most 5 times in the past year. goodluck hope this helps
Apr 23, 2014 | Vehicle Parts & Accessories
Engine dies when hot fuel not pumped round the system kohler 18hp
If the engine has a black pump on the side of the engine it may be faulty, there is a diaphram inside, but the pump is non servicable, it takes a pulse from the cylinder head or rocker box, this pulses the diaphram, which then pumps the fuel, as there is no gravity feed from the tank, it requires the pump to fill the carb.
May 19, 2012 | Garden
I have a suburu LEGACY GX its been unused for about 2 years, but I have turned the engine over now and again,,,I have recently put it back on the road,, it ran fine before,,but now after starting in will...
hi this sounds to me like its def a fuel problem, if you have done the fuel filter i would check for mositure or water in your fuel, if that comes back ok i would check your fuel pump relays or the actual pump itself
Jun 01, 2011 | 1990 Subaru Legacy
Car cuts off completely after driving 30 minutes or more, But will start back up after Letting it sit for 5 minutes. For several months I had a code 6 and 7 that came up when I had the car plug into the...
Sounds to me the converter may be stopping up. Run fine the after a shrot time will die and have to wait to restart. As it gets worse you will have a strong odor,
Mar 20, 2011 | Mercedes-Benz CLK Cars & Trucks
1995 LeSabre - Starts and runs fine, but engine cuts off without warning. First time, 5mph in a crowded school commute traffic. Put in park, and started right away. Second time, after turning onto...
If the motor gets hot and cuts off and will not start for a period of time the problem would be the crank sensor. The sudden cut off and starting right back up can be due to dirty battery cable connections. Remove them from battery and clean all three of them with a wire brush and replace both bolts.
Jan 22, 2011 | 1995 Buick LeSabre
Car stalling out and bot starting after being driven for awhile.
mcdevito75 Here, It"s possible the ignition Module is going bad, no way to test and if so, one day the car will not start at all.----------It can also be a vapor loc, wher the fuel is evaporating before it reaches the cylinders. Best Bet, have your local shop check both these items.
Jan 01, 2010 | 2000 Dodge Stratus
2001 Buick Regal cuts off while driving at times also won't start
The ignition switch on that model is rated @ 50amps. When I was driving my 2001 Regal LS (at 120,000 miles) and used the turn signal, the engine would die, when I switched the turn signal off, the engine ran. So I replaced the ignition switch, and all is well.
Mar 24, 2009 | 2001 Buick Regal
Car sometimes will not start
have the fault codes read
Oct 28, 2017 | 2004 Ford Taurus
Vehicle No Start - no turnover (lights, radio work) then it starts
It may be your harmonic balance. do you hear a rattling noise when it runs?
If not it could be a bad or going bad starter.
Oct 01, 2008 | 1994 Oldsmobile 88
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
358 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
