I'm considering building an SBS Server on an xSeries 205, pretty basic with mirrored IDE drives for the OS and then a 3rd hard drive for data, with a DDS backup drive (with a SCSI card) & 768MB ram. Probably go with a P4 1.4GHz. Just curious if anyone else run IBM xSeries boxes with SBS and how it has been? Thanks for any input.
I appreciate your info. I'm looking to go the x225 route now, with a similar configuration. Did you get the IDE or SCSI 20/40 Tape Drive? Also, I'm curious to how you decided to go with RAID 5 instead of using the onboard controller for RAID1? I'm trying to make this sort of determination right now and am up in arms over whether to go with 2 for RAID1 or 3 for RAID5.
Thanks,
Paul
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on IBM xSeries Server - Any good?:
Solution #3
posted on Aug 02, 2007
Melissa - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I appreciate all the good comments. I suppose it makes more sense to just get 2 huge IDE drives and mirror them data and all. Will that affect the performance a ton? The SBS site this will be for is only going to use SBS for strictly File & Print nothing else.
From what I hear everyone saying, I would like to consider going with SCSI drives. The reason I am looking at IBM is because a large PC refresh order will accompany this so we can stick to a single vendor.
Looking at the 225 xSeries with 2-36.4GB Ultra160 SCSI SL HDD's with or without the 4Lx RAID controller - what does the RAID controller add (is that the difference between hardware and software RAID?)
I'm also planning on buying the IBM 20/40GB DDS/4 4-mm Internal Tape Drive(HH), wondering if anyone has had good experiences with this?
Thanks for your input and assistance,
-Paul
Solution #4
Phoebe - usenet poster
I have SBS on a number of Xseries, but nothing as low as a 205. Our normal entry level is a 220, with a pair of 18Gb SCSI drives, adding a 4Lx RAID controller and a third drive for sites with SQL, or more than 10 users. W2K has a quirk that requires manually killing a process during install when using an IBM RAID adaptor, (MS bug, not IBM), but other than that they have worked well for us. The 205 is nothing special, just another clone PC, although a bit more expensive, well built, and fairly well supported.
SBS is generally bottlenecked by HDD speed, a fast CPU will not compensate for IDE HDDs.
Mal Osborne
Solution #5
M0nica L - usenet poster
Paul, if going with IDE drives (which are available in very large capacities) why not just use two large ones (mirrored) partitioned for both OS and data. That way both are protected?
You may also want to look at Dell PowerEdge 600SC with 1.8GHz P4 (512mb cache). If buying new, it would probably be less expensive and better performing than the IBM.
Pat
