Won't print after cartridge moved manually.
Won't print. Worked fine until I moved printer cartridge manually to see what number to buy as replacement. Printer cartridge moved to far left of printer and seems to be stuck in place now.
  • jchmay Mar 10, 2009
    Shutting it off didn't work. How do you run the cartridge realignment porgram?
  • 3,051 Answers
Hi there
you can manually move it back to the center again and run the cartridge alignment program on the printer or just jhut off the printer and restart it and see if that helps
Posted on Mar 10, 2009
  • Michael Thomas
    Michael Thomas Mar 10, 2009
    do you know how to get to the clean cartridge section if so it will be in there
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Will not print text in documents, only headings.
When you go to print on your settings select print in black only. Did you buy Brother ink? Having old cartridges refilled or buying generic can pose a problem. I remember correctly brothers have a chip on the ink cartridge? I have gone through so many printers and its really not worth going any further, seems as though you have put sometime and effort in to this 100$ printer. Take 100$ & buy a kodak easy share all in one the ink is 15$ brand new.
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
The cartridge is moving like it is printing. But
make sure that the ink cartridge is full and is securley snapped into place. If you have alreayd checked that then chances are the printing head of your printer is damaged or the motor that move sthe printing head is damaged. Call the manufacturer and demand that you get a replacement printer (asumming that the one you have is under warranty).
Jul 02, 2009 | IBM Lexmark Z715 InkJet Printer
I need your help my printer quit printing, I was low on ink and it quit printing after I printed a page. I changed cartridges and it still would not print, so I swapped cartridges with a different printer...
So it prints the self test (test page) or not?
If nothing is printing from at all (printer moves likes it is printing when in operation, but no ink hitting paper) there may be a blockage on the jets or the information is not getting to the printer properly if these same cartridges work on another printer.
I would lift lid and carefully check each one and wipe with a thin cloth the remove any clotted ink and dirt.
You have already reinstalled the drivers, but I would get the latest ones you can from www.hp.com
Finally I would cold reset the printer - usually holding the go button pressed in while hitting the power button on and off - will reset rthe calibration and give you a better chance of fixing.
Also if you have the cartridges for the wrong model, they may physically fit in, but the chip on the cart will tell the printer theres a problem and won;t print.
Summary:
- Check cartridges - off the top of my head (please check!) you should be using HP 45 for Black and HP 68 for Colour (if using a different brand, fine but the numbers are thee same)
- Download latest drivers
- Cold reset printer and install again
Good Luck
Mar 14, 2009 | HP DeskJet 940c InkJet Printer
Isn't printing at all...
try replacing the cartridge with the new one
Mar 14, 2008 | Canon BJC 80 InkJet Printer
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Unable to print using black printer cartridge
Well, Yeah mine did the same thing!!
And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
Then,
Once you get home replace it with the others.
BUY THE BLACK INK! not the TRI-COLOR!
Sep 25, 2006 | Dell A920 InkJet Printer
55 people viewed this question
jasbo
jasbo
