Question about Canon PowerShot A75 Digital Camera
My camera is a Powershot A80. Error E18? What does this mean?
After years of good reliable use it suddenly refuses to work. I gives a repeated clicking sound, then an error message E18. I had taken 150 or so pictures, several short films, over the previous few days, then nothing. Any suggestions?
  • Anonymous Mar 15, 2009
    e18
    Novelist:
  • 98 Answers
Dear Cheuer,
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off or it may not even powe on.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a problem.
You can also try the following ;
1). Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it, hopefully, it should come back to life.
If still you have a problem, then
2). Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
3). If it is still stuck, please do ensure that you use fully charged batteries, now place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
If Still it does not start, try to
4). Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5). Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont hit very hard please. you might damamge something else
The last solution is if you are good with small screws, then you could open and clean the lens barrel. I can guide you on that, but if you are hesitant then please go to the nearest Canon Service center.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18
Posted on Mar 10, 2009
  • Sachin
    Sachin Mar 10, 2009
    could the error be solved or did you find a solution? Please do update
Have Canon PowerShot A80. New batteries, turn on and it automatically turns off with a buzzing/clicking noise... Window shows error E18
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try:
Nov 14, 2009 | Canon PowerShot A80 Digital Camera
It says e18 on the screen
a chip on the boar has burnt out
Oct 18, 2009 | Canon PowerShot A80 Digital Camera
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
My Canon PowerShot A80 Digital Camera on and then off
If the E18 error code comes along with unusual noises while moving the lens, there may be a problem with the mechanics. Just tap the camera on a solid surface a few times. I had the same problem and tapping helped just fine.
Mar 01, 2009 | Canon PowerShot A80 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
E18 displayed on Powershot Canon A80
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Nov 02, 2008 | Canon PowerShot A80 Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
E18 Error
Sorry to hear that. I have an A80 also, and I really like that camera (swear it takes better pictures than even my A620).
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 11, 2008 | Canon PowerShot A80 Digital Camera
Unuseable Camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Canon PowerShot A80 Digital Camera
Help with code
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Oct 05, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot A75 Digital Camera Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
