Question about Dahlquist ORBIT 5.1A System
Fuse on subwoofer keeps blowing
My subwoofer blow a fuse the other day and when I replaced it with a new fuse that one also blew. can you tell what else could be wrong
  • cheemo Mar 13, 2009
    I haven't tried anything yet.
I have an sw303 gateway subwoofer that is having the same problem. I disconnected the speaker and turned the volume all the way down and it still blows. Any other things I can check?
Posted on Nov 21, 2009
  • 26 Answers
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Posted on Mar 10, 2009
15 amp a/c clutch fuse keeps blowing. why is it doing this?
Sounds like the magnet in the a/c clutch has failed.
Jul 02, 2012 | 2001 Oldsmobile Aurora
Radio windows and sun roof fuse keeps blowing
Chafed wiring is my suspicion. The door wiring is a prime culprit, where the harness leaves the car body and enters the door.
Get a blown fuse, wire a 12v 21watt lamp across it and plug it in. The light will go out or flicker as you find the faulty wiring.
Jan 24, 2018 | 2004 Ford Explorer
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Fuses keep blowing
This particular product has a lot of comments posted on it and I've answered a few of them now so I'm beginning to think you may want to look into weather or not the manufacturer has received any complaints or this is just a freak occurrence. Keep in mind not all commments are the same so this may just be nothing. Either way I can tell you this much, if fuses keep blowing quickly, over and over again-You have a direct short somewhere and will most likely be in need of professional assistance of some sort with the possiblilty of having to replace it. I'm sorry it's not an easier fix but it may not be too expensive.
-Dynami
Mar 22, 2009 | JBL PB12 Subwoofer
Dahlquist ORBIT 5.1A System Logo
1,289 people viewed this question
Top Dahlquist Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dahlquist Audio Player and Recorder Expert? Answer questions, earn points and help others
